sethuchidambaram
source tree for 4.9.35-v7+
Fri May 03, 2019 6:27 am
I need the exact source tree for the above kernel 4.9.35, to write device drivers for rasberry pi, anything that is generic such as 4.9.x is not working.
Re: source tree for 4.9.35-v7+
Fri May 03, 2019 7:47 am
Why are you using something that ancient? (30 Jun 2017)
Current stable kernel is 4.14.98
Current development kernel is 4.19.37
fanoush
Fri May 03, 2019 1:33 pm
if you need just to compile matching kernel modules and not recompile whole kernel you don't need whole source tree, in general there is package kernel-headers or linux-headers for this in most linux distributions. In raspbian I think the names are:
raspberrypi-kernel
raspberrypi-kernel-headers
so you need to install same version of -headers as your curently installed rapberrypi-kernel.
Then the Makefile of your external kernel drivers/modules source should find it and build fine.
sethuchidambaram
Sun May 12, 2019 10:45 am
Hi This is the Model of my rasberry pi " Raspberry Pi 3 Model B Rev 1.2" and my current kernel version is 4.9.35-v7+ , i build my own kernel image from the source tree, I tried the methods found in the forum the Image gets created but I am unable to boot from it. If I need use this kernel 4.14.98 for my above said rasberry pi model, How do I download this new kernel or how do download ths source tree for the above said kernel version and create the Image?
sethuchidambaram
Sun May 12, 2019 11:15 am
Hi Fanoush,
Thks for the reply you have said "so you need to install same version of -headers as your curently installed rapberrypi-kernel",
once you write the driver code you need to run this make command "make -C /usr/src/linux-headers-4.15.0-1035-aws M=`pwd` modules" to generate the .ko file to laod the module, the given make command is for the kernel version 4.15.0 which is a ubuntu OS for which the source tree was given and I was able to get the header file and was able to load the firmware.
But for my RAsberry Pi I am unbale to get the header file for my exact version "4.9.35-v7+" why the rasberry pi is distrubuted with out the source tree. only if the header file version matches to that of my kerner version, I can do Insmod, otherwise it throws out an error.
fanoush
Fri May 17, 2019 6:17 am
all kernels and matching headers since 2016 can be seen here https://archive.raspberrypi.org/debian/ ... -firmware/ they are named by date and not by linux version so you need to figure out what raspberrypi-kernel version you have installed and then install matching headers package.
Return to “Raspbian”
