skim
How can I upgrade to Raspbian Lite April 2019 version?
Thu Apr 11, 2019 3:06 am
Tried searching for ways to check if I have the April 2019 version, but none of the commands below output what I need:
$ uname -a
$ lsb_release - a
$ cat /etc/os-release
$ cat /etc/rpi-issue
The last one is the closest one and reports the following:
Raspberry Pi reference 2018-11-13
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 7e0c786c641ba15990b5662f092c106beed40c9f, stage2
But I'm not sure how/when this gets generated.
When running apt-get commands, I get nothing
$ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
$ sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Re: How can I upgrade to Raspbian Lite April 2019 version?
Thu Apr 11, 2019 7:12 am
$ uname -a
$ lsb_release - a
First and foremost it is not a new version, it is just all the updates since November 2018 rolled into a new point release.
Raspbian Stretch to fully update:
sudo apt update
sudo apt full-upgrade
bongofury
Thu Apr 11, 2019 7:29 am
Thanks fruitoftheloom, so much in theory. But doesn't do what was asked.
Thu Apr 11, 2019 8:37 am
So what are you expecting it to do?
skim
Thu Apr 11, 2019 2:09 pm
sudo apt update
This seems to say otherwise: https://downloads.raspberrypi.org/raspb ... _notes.txt
  * Chromium browser updated to version 72
  * VLC media player updated to version 3.0.6
  * RealVNC Server updated to version 6.4.0
  * Flash player updated to version 32.0.0.156
  * Performance improvements to SDL library
  * Performance improvements to pixman library
  * Option to set display underscan added to startup wizard
  * Mounted external drives now displayed on desktop by default
  * Network plugin modified for improved compatibility with wpa_passphrase
  * SD Card Copier tweaks to reduce copy failures
  * Various minor bug fixes and appearance tweaks
  * Added ethtool
  * Added rng-tools
  * Add PINN restore support
  * Linux kernel 4.14.98
  * Raspberry Pi firmware f8939644f7bd3065068787f1f92b3f3c79cf3de9
Thu Apr 11, 2019 2:19 pm
sudo apt update
  * Added ethtool
  * Added rng-tools
chromium-browser was released a couple of weeks ago, have been using:
viewtopic.php?t=236393
The Raspberry Pi Desktop Splash Screen was updated end of last week, prior to this point release.
VLC was update to 3.0.6 a while ago:
viewtopic.php?t=227185&start=50#p1416179
So as I stated it is just a point release and a full update / upgrade of a previous Stretch install will have the same default package versions as this one........
....but you need the "Raspbian Stretch with desktop and recommended software" as Lite has no GUI !
:shock:
Thu Apr 11, 2019 5:07 pm
The only difference I see there is that ethtool and rng-tools are now installed as standard. If you want those packages, just install them. The rest of the changes will be picked up with an upgrade.
Unreadable squiggle
Thu Apr 11, 2019 5:45 pm
ethtool is used to query and control network device driver and hardware settings, particularly for wired Ethernet devices.
rng-tools is a set of utilities related to random number generation in kernel.
Nice extras for those who have needed them.....
Thu Apr 11, 2019 5:52 pm
I usually install ethtool anyway. I find it a bit better than mii-tool in some cases.
Unreadable squiggle
skim
Fri Apr 12, 2019 1:01 am
Thanks everyone, will install those two packages manually 👍
Yeahthisisausername
Fri Apr 12, 2019 9:10 pm
Also, if you want the newest kernel, which is 4.19, and not 4.14, just open the terminal and type:
sudo rpi-update
It'll update the kernel and you'll have to reboot. If you have ANY issues after this, then revert back to 4.14. I've been using 4.19 for about two days now, and haven't experienced any issues, for what it's worth.
Fri Apr 12, 2019 11:40 pm
That is a very bad idea. There's bits in the latest kernel (last week I ran rpi-update) that are broken on 3B and 3A+. That breaks the on-board WiFi. I'm out of the country until tomorrow so this week's update may be better - not tested it.
It's never needed for regular users. It can leave your system unbootable.
DO NOT recommend running rpi-update as you will be very unpopular when it breaks things.
Return to “Raspberry Pi OS”
