tigernero
How to get latest apache2 and php versions on Raspbian Os
Wed Apr 10, 2019 11:52 am
As many of you will know, Raspbian is optimized for our raspberry,
which in the lite version is extremely light and is suitable for various types of installations, including the LAMP web server.
Like all Debian derivatives, raspbian also lacks in having among its repositories the latest versions that we need for the security of our LAMP environment.
After various studies, I came to understand how to get the 2 main elements that make up a web server, apache and php.
as regards the installation of the latest php version, it will be sufficient to add the deb sury org repository to our os to then install or update them.
deb sury org contains the latest versions of php 7.0 / 7.1 / 7.2 / 7.3. in the nosytro case for those wishing to have php 7.3
just give these commands:
1) sudo apt-get -y install apt-transport-https lsb-release ca-certificates
2) sudo wget -O /etc/apt/trusted.gpg.d/php.gpg https://packages.sury.org/php/apt.gpg
3) sudo sh -c 'echo "deb https://packages.sury.org/php/ $ (lsb_release -sc) main"> /etc/apt/sources.list.d/php.list'
4) sudo apt update
having done that we could install any version of php, I will examine last php 7.3
just give command
sudo apt-get install php7.3 libapache2-mod-php7.3 php7.3-cli php7.3-common php7.3-mbstring php7.3-gd php7.3-intl php7.3-xml php7. 3-mysql php7.3-zip php7.3-curl php7.3-ldap php7.3-bz2 php-ssh2 php-apcu php-smbclient php-imagick libmagickcore-dev -y
to have everything we need php 7.3 sources obviously you will also have last php 7.3-fpm if you want
FOR APACHE2 THE ISSUE WAS MORE COMPLEX
since the deb sury org repository is designed for os debian and not for its derivatives.
raspbian has in its repository apache2 version 2.4.25 which does not contain the latest security patches see apache 2.4.39
to be able to install the latest apache we need a library located in the stretch-backport repositories
reposities that are not installable on raspbian except with a guide that I created and resolves
Let's start by putting the apache2 repositories of deb sury org
APACHE
2) sudo wget -O /etc/apt/trusted.gpg.d/apache2.gpg https://packages.sury.org/apache2/apt.gpg
3) sudo sh -c 'echo "deb https://packages.sury.org/apache2/ $ (lsb_release -sc) main"> /etc/apt/sources.list.d/apache2.list'
4) sudo apt update
having done that we need the dependency of libbrotli1 that we don't have in raspbian and in order to get it we have to get it from the debian backport repository
I solved this way:
I added backport repository in source.list
1) sudo nano /etc/apt/sources.list
I added
deb http://deb.debian.org/debian stretch-backports main
I installed dirmngr which serves to get the keys of the repository
2) sudo apt install dirmngr
added the following keys taken from ubuntu (those from debian didn't find them but they are the same
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7638D0442B90D010
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8B48AD6246925553
I imported them in the apt-key
sudo gpg -a --export 7638D0442B90D010 | sudo apt-key add -
sudo gpg -a --export 8B48AD6246925553 | sudo apt-key add -
installed the dependency that was missing with the command
sudo apt-get -t stretch-backports install libbrotli1
and I tried to install apache2 and it worked
sudo apt-get install apache2 -y
I got our working apache 2.4.39 on raspbian.
from this moment apache2 and php will always receive the latest versions available
Thanks to those who followed me here
Re: How to get latest apache2 and php versions on Raspbian Os
Wed Apr 10, 2019 12:05 pm
Which patches are missing?
Debian based systems always backport the security patches to the older stable versions of all software. That is one of the main reasons people use it.
Unreadable squiggle
Wed Apr 10, 2019 1:15 pm
4) sudo apt update
just give command
APACHE
4) sudo apt update
I solved this way:
I added
Alternatively you could run Buster Lite Testing ???
tigernero
Wed Apr 10, 2019 1:37 pm
you wouldn't still have the latest versions as from the Deb sury org repository
tigernero
Wed Apr 10, 2019 1:39 pm
https://bobcares.com/blog/apache-2-4-x- ... erability/
the slowness in having the latest apache2 and PHP versions is the reason why I made this guide. let's not forget that raspbian uses basic PHP 7.0 deprecated by now.
Wed Apr 10, 2019 1:47 pm
Buster has PHP7.3
https://packages.debian.org/buster/php7.3
Apache 2.4.38
https://packages.debian.org/buster/apache2
tigernero
Wed Apr 10, 2019 1:50 pm
Deb sury org apache2 versione 2.4.39
Deb sury org PHP 7.3.3
Wed Apr 10, 2019 2:02 pm
Fixed (along with others) in the current 2.4.25 release on Stretch.
apache2 (2.4.25-3+deb9u7) stretch-security; urgency=medium
  [ Xavier Guimard ]
  * CVE-2018-17199: mode_session: Fix missing check for session expiry time.
    Closes: #920303
  [ Stefan Fritsch ]
  * mod_http2: Fix keepalive timeout behavior. This fixes a regression with
    Safari web browsers, introduced in 2.4.25-3+deb9u6. Closes: #915103
  * Fix typo in apache2_switch_mpm() in apache2-maintscript-helper.
    Closes: #904150
  * CVE-2018-17189: mod_http2: Fix DoS via slow, unneeded request bodies.
    Closes: #920302
  * CVE-2019-0196: mod_http2: Fix read after free
  * CVE-2019-0211: All MPMs: privilege escalation from www-data user to root.
  * CVE-2019-0217: mod_auth_digest: Access control bypass
  * CVE-2019-0220: URL normalization inconsistincy.
    Consecutive slashes in URL's are now merged before use in LocationMatch
    and RewriteRule. The old behavior can be restored with the new directive
    "MergeSlashes off".
 -- Stefan Fritsch <sf@debian.org>  Tue, 02 Apr 2019 21:05:13 +0200
Unreadable squiggle
tigernero
Wed Apr 10, 2019 2:03 pm
ok I've read all the way through now, but why isn't it possible to have the latest release instead of making a bug fix on the current 2.4.25?
to have a basic version of php 7.3 in raspbian you will have to wait a lot?
Wed Apr 10, 2019 2:16 pm
Because that is the whole point of Debian's Stable release system. Once a release is classed as stable you are guaranteed that software versions will not change and only backported security patches will be released. This can be critical in a production server environment where you don't want to be doing upgrades because of security fixes and suddenly find the "--banana" option to the "fruity" package suddenly produces oranges instead, or doesn't even exist any more and your critical server will no longer start (I have seen it happen on other systems where sysadmins thought they were being clever with upgrading to the latest version all the time). Yes, adequate testing should catch things like that, but it doesn't always.
Newer versions are available in Debian's (and Raspbian, of course) Testing release, called Buster. Buster is getting close to replacing Stretch as the new Stable release and Stretch will become Oldstable. There will then be a new Testing branch.
Unreadable squiggle
tigernero
Wed Apr 10, 2019 2:19 pm
I noticed that to update apache2 to 2.4.39 from the repository odrej lacked the package: "libbrotli1"
which is why I had to force installation of the debian backport repository
and find it there and install it with the command
does this package exist in the buster channel if desired?
or is it only found in debian backport?
how to enable Debian's (and Raspbian, of course) correctly on raspbian?
Wed Apr 10, 2019 2:23 pm
It would appear that the OP requires a rolling release which is not Debian, Arch Linux Arm should fit:
https://archlinuxarm.org
php 7.3.4-2
https://archlinuxarm.org/packages/armv7h/php
apache 2.4.39-1
https://archlinuxarm.org/packages/armv7h/apache
brotli 1.0.7-1
https://archlinuxarm.org/packages/armv7h/brotli
Last edited by fruitoftheloom on Wed Apr 10, 2019 2:27 pm, edited 1 time in total.
Wed Apr 10, 2019 2:26 pm
https://packages.debian.org/buster/libbrotli1
castletonroad
Wed May 01, 2019 11:07 am
Hmmm...
I followed OP's advice, but Nextcloud was still reporting PHP7.0xxx, despite php -v showing that PHP7.3 was installed.
I purged 7.0x.... and then my Apache setup stopped working - couldn't process php pages.
Wasn't sure where to go with this, so have reverted to PHP7.0x as per stretch...
Raspberry Pi 4 Model B | Raspberry Pi 3 Model B | Raspberry Pi 2 Model B
planteg
Fri May 10, 2019 3:50 pm
using the latest Noobs (April 2019) I installed Raspbian, the I ran the first commands. All was well but for the last one:
Err:5 https://packages.sury.org/php $ Release
  404  Not Found
E: The repository 'https://packages.sury.org/php $ Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Could latest changes explain the issues ? I can provide the complete output if that helps. I will carry on with the other instructions and post back the result
My goal is to istall LAMP in order to install Joomla! I have had many issues using what worked for me before.
EDIT
I couldn't install PHP 7.3. I first got a zillion of (the messages are in French, I translated this one in English like this):
Note : selection of php7.0-apcu for rational expression « php7. »
That was followed by a zillion of messages like this one :
E: Couldn't find any package by glob 'php7.3'
Why in the world is it so complicated to install packages
Gilles Plante
geev03
Fri Jul 19, 2019 9:07 pm
The link https://www.linuxbabe.com/debian/instal ... -10-buster has all the necessary steps for a hitch free LAMP installation( see the attached screen shot).
castletonroad
Fri Jul 19, 2019 9:26 pm
@geev03
Yes, but can you confirm that you have this running successfully on a raspberry pi? The issue is with php-7.3 being difficult on Raspbian...
Sat Jul 20, 2019 6:11 am
@geev03
The current Raspbian (Buster) uses PHP 7.3 by default. The issue here was an old one. I don't currently have a Pi running that version and I don't have time this morning to test it out, but I have no reason to believe there would be any difficulty with installing it.
Unreadable squiggle
geev03
Sat Jul 20, 2019 6:27 am
@geev03
The sd card used on a Pi4B is now in a Pi3B , php 7.3 is working. Please see the following
login as: pi
pi@192.168.1.234's password:
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jul 19 20:55:17 2019 from 192.168.1.75
pi@raspberrypi:~ $ php -v
PHP 7.3.4-2 (cli) (built: Apr 13 2019 19:05:48) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.4, Copyright (c) 1998-2018 Zend Technologies
    with Zend OPcache v7.3.4-2, Copyright (c) 1999-2018, by Zend Technologies
pi@raspberrypi:~ $
PuffMD
Sat Jul 20, 2019 10:43 am
Hi OP,
I tried following your instruction but i am getting errors when i try to run the update:
pi@RaspberryPi-CP1:~ $ sudo apt update
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Ign:3 https://packages.sury.org/apache2 $ InRelease
Err:4 https://packages.sury.org/apache2 $ Release
404 Not Found
Reading package lists... Done
E: The repository 'https://packages.sury.org/apache2 $ Release' does not have a Release file.
pi@RaspberryPi-CP1:~ $ sudo apache2 -v
Server version: Apache/2.4.25 (Raspbian)
Sat Jul 20, 2019 1:44 pm
Hi OP,
404 Not Found
Start with a fresh install of Raspbian Buster which as of 20th July 2019 is the currently supported Operating System.
Then update:
sudo apt update
sudo apt full-upgrade
sudo reboot
Then install PHP / Apache
sudo apt update
sudo apt install apache2 php7.3
tigernero
Mon Jul 22, 2019 4:58 pm
You give the commands back, and you will notice that although there are still no buses, the armhf repositories exist.
personally on a pi3b + configured and have updated the openssl to 1.1.1.c compared to the basic 1.1.1.b. as well as php 7.3.6 which has an updated raspbian buster to 7.3.7 with deb sury org.
for apache2 still have not put new release 2.4.39 for armhf will come out soon
I have no problems, double-check the commands
hanslepire
Thu Aug 29, 2019 9:41 am
I had to change the line to force buster version :
to
3) sudo sh -c 'echo "deb https://packages.sury.org/apache2/ buster main"> /etc/apt/sources.list.d/apache2.list'
If not, it was not working automatically and after that I had an error :
Exception of that, thank you for your explication, it works very well and I get the last version of Apache2.
Regards
Return to “Raspberry Pi OS”
