AirFiero
Re: What is the small partition visible to Windows?
Thu Apr 11, 2019 6:52 pm
Andyroo wrote:
Thu Apr 04, 2019 5:27 pm
Basically if your root partition fills your machine stops.
FAT is also not as good for fragmentation handling as EXT format drives.
If you need to write to the Pi SD card it’s a simple job to set up SAMBA on the Pi or add EXT drivers to a PC or Mac and use the main SD / disk space.
Good idea about using Samba, here is a video describing using Samba with PiCorePlayer and it looks like it uses a simple HTML browser based configuration interface
https://youtu.be/DJrlW26Uh48
Return to “Raspbian”
