wpasupplicant update?
Posted: Tue Mar 05, 2019 6:41 pm
by algorithm
What sort of update is this that downgrades the cypher & security level?
wpasupplicant (2:2.6-19) unstable; urgency=medium
  With this release, wpasupplicant no longer respects the system
  default minimum TLS version, defaulting to TLSv1.0, not TLSv1.2. If
  you're sure you will never connect to EAP networks requiring anything less
  than 1.2, add this to your wpasupplicant configuration:
    tls_disable_tlsv1_0=1
    tls_disable_tlsv1_1=1
  wpasupplicant also defaults to a security level 1, instead of the system
  default 2. Should you need to change that, change this setting in your
    [email protected]=2
  Unlike wpasupplicant, hostapd still respects system defaults.
 -- Andrej Shadura <[email protected]>  Sat, 15 Dec 2018 14:22:18 +0100
Re: wpasupplicant update?
Posted: Tue Mar 05, 2019 6:51 pm
by ShiftPlusOne
This looks like the relevant discussion:
https://bugs.debian.org/cgi-bin/bugrepo ... bug=911297
I haven't looked at it too closely. We just backported the buster version to stretch, to fix issues people reported with wpa_supplicant and hostapd.
Posted: Tue Mar 05, 2019 7:17 pm
by algorithm
Thanks. What a mess. I'll have to check if the eduroam network I use sometimes does indeed require tlsv1.0 and level=1.
Posted: Wed Mar 06, 2019 7:03 pm
by jpgview
Is the following a correct assumption?
In order to restore the original security settings, you need to add the following to /etc/wpa_supplicant/wpa_supplicant.conf
[email protected]=2
The file (my Raspbian configuration - latest version November 2018) already contains the following entries:
update_config=1
How do you apply these modified settings? Reboot? Is there a command that activates the new settings, provided the settings are indeed correct?
Thanks for your time and effort.
Posted: Wed Mar 06, 2019 7:42 pm
by algorithm
That was my interpretation, too, yes. However, make sure to try it first with a non-headless Pi (screen and keyboard/mouse connected) because for some reason these changes after reboot left my Pi3+ unable to connect to my home network... Very strange, because my router is less than a year old and I'm sure it implements tls1.2. I thought this was only an issue with very old equipment or PEAP authentication company networks stuck in legacy mode. Faulty implementation of the fix, perhaps.
Posted: Wed Mar 06, 2019 7:48 pm
by jpgview
Apparently, this is being discussed here (https://www.raspberrypi.org/forums/view ... p?t=235128)
It looks like adding the new settings wasn't very successful for this user.
Meanwhile, I've added the settings to /etc/wpa_supplicant/wpa_supplicant.conf and rebooted. No problems sofar, but I made sure to connect to the pi, using ethernet (wired).
Still would like to know if adding the settings restore the security level.
Posted: Sat Mar 09, 2019 5:02 am
by Milliways
I just updated Raspbian and didn't see this BUT I got the following - this broke hostapd, and it seems to require manual enabling
NOTE I had a valid /etc/hostapd/hostapd.conf and a working installation prior to "upgrade" based on https://www.raspberrypi.org/documentati ... s-point.md
apt-listchanges: News
wpa (2:2.6-10) unstable; urgency=medium
  The hostapd .service file is now automatically masked every time the
  package is upgraded with no valid configuration.
  The plan is to deprecate /etc/default/hostapd at some point, making
  /etc/hostapd/hostapd.conf the standard location for the configuration
  file.
 -- Andrew Shadura <[email protected]>  Tue, 28 Nov 2017 12:29:21 +0100
wpa (2:2.6-8) unstable; urgency=medium
  Since 2:2.6-6, hostapd ships a systemd .service file. As hostapd comes
  with /etc/default/hostapd file, which by default doesn't specify any
  config file, to prevent installation or boot failures, the package's
  postinst script masks the hostapd.service unit on the first install.
  After editing the default file, users need to unmask it themselves.
 -- Andrew Shadura <[email protected]>  Sun, 26 Nov 2017 19:25:50 +0000
Posted: Mon Mar 11, 2019 2:19 pm
by eehmke
I was too fast and added the suggested lines
on my headless pi. Now it is not accessible anymore, and I have to drive 80+ km and climb onto a roof to get the sd card. Should I just remove those lines, or what is a safe way to make it work?
Posted: Mon Mar 11, 2019 6:44 pm
by gkaiseril
That happened to me and I removed the lines. I still get the warning but updating, upgrading and internet work.
When running some perl programs like cowsay I also see the following waring.
$ cowsay moo
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
I seem to have fixed both my issues by changing the locale setting using rpi-config and forcing a reboot of the system. I changed languages and timezone and then set the back to the desired settings. This forced a reboot of the system.
Posted: Tue Mar 12, 2019 11:30 am
by eehmke
I did a test on a similar system and found this lines in the system log:
unknown global field 'tls_disable_tlsv1_0=1
So wpa_supplicant failed to start because of unknown lines in the config files. Seems something is broken, or where are these lines supposed to be? I have them in /etc/wpa_supplicant/wpa_supplicant.conf. For now, I comment them out.
Posted: Tue Mar 12, 2019 4:05 pm
by Paeryn
According to the example conf, inside each network block as part of the phase1 parameters (the example conf says it can be used in phase2 as well)
network={
        ssid="myssid"
        psk="passkey"
        phase1="tls_disable_tlsv1_0=1 tls_disable_tlsv1_1=1"
