ronnih
After edit file over ssh the file is empty. All data lost :(
Sun Mar 03, 2019 7:00 pm
had today discover some terrible.
On my Raspberry X i open my file manager PCManFM 1.2.5 and made a ssh-connection to my Raspberry Y with sftp://ronni@stretch_fhem/home/ronni
Now i open a text-file on my Raspberry Y with Leafpad edit some lines and save the file, close Leafpad and close PCManFM and thus the SSH connection to Y.
After hours of amazement and troubleshooting, I found that the text file I had previously edited was empty :o
I was able to reproduce this phenomenon with other text files as well.
My Question is: How can I edit files in Raspbian graphically via SSH? Without installing additional software.
Thx and Regards
Ronni
https://techguru.lima-city.de
B.Goode
Re: After edit file over ssh the file is empty. All data lost :(
Sun Mar 03, 2019 7:06 pm
The situation you describe is consistent with a microSD card that has spontaneously (and probably irrevocably) entered a Read Only state.
If this is the case it will be unrelated to the fact that you are making a remote access connection to edit the file.
Do you have a direct keyboard/monitor connection to your RPi: can you reproduce the symptoms in that scenario?
ronnih
Sun Mar 03, 2019 7:39 pm
Hello B.Goode,
the SD Cards on my Raspberrys are all good and had no problems. If I make a SSH Connection over LXTerminal I can edit every file and save the changes with no Problem. Only If I edit the files with SSH Connection over FileManger(PCmanFM and Leafpad) the file has 0 Byte after edit.
Return to “Raspberry Pi OS”
