davethomaspilot
How to debug slow shutdown on Stretch
Fri Feb 15, 2019 5:48 pm
I have hardware that monitors a GPIO defined in a dt-overlay that to determine that the rpi has completed shutdown. When the signal goes active, the five volt supply powering the rpi is turned off.
I initiate a shutdown using:
 sudo shutdown -hP now
Sometimes the shutdown occurs in just a few seconds, but sometimes it takes many seconds--probably 30 seconds or more.
I can verify the pi has not really shutdown, not only by a LED be driving by a separate power management processor, but also by pinging it. When the pi is slow to shutdown, I can verify it is still up by pinging it (it is wifi connected to a router).
I can repeat the shutdown experiment and about 2/3 of the time, the shutdown is immediate, but in about a third of the cases, the shutdown time is long.
How to I debug what is causing the slow shutdown?
Return to “Raspbian”
