Hi, with the Raspberry 0 W you can setup a headless system by turning the board to an access point and connecting to it from other clients. This is more convenient than connecting the board to an existing wifi network, for example if you don't have such a network in all the places you use it.
Now you could do that by simply editing configuration files on the sd from another computer, the only problem is that you have to install hostapd, and that forces you to connect the first time to the Zero with a monitor and keyboard, or use a Raspberry 3 to boot into the system via ethernet.
[Reference: https://www.raspberrypi.org/documentati ... s-point.md]
Michele Alessandrini
