rmast
libegl1-mesa package broken dependency?
Sat Dec 29, 2018 6:59 pm
On stretch on my Rpi3 a similar issue:
pi@raspberrypi:~ $ sudo apt-get install libgles2-mesa-dev
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
libgles2-mesa-dev : Depends: libgles2-mesa (= 13.0.6-1) but 13.0.6-1+rpi2 is to be installed
Depends: libegl1-mesa-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Re: libegl1-mesa package broken dependency?
Sat Dec 29, 2018 7:18 pm
Unrelated to the previous issue.
Did you do
sudo apt-get update
first?
What does
apt-cache policy libgles2-mesa-dev
show?
rmast
Sat Dec 29, 2018 7:50 pm
Did you do
sudo apt-get update
first?
yes
What does
show?
pi@raspberrypi:~ $ apt-cache policy libgles2-mesa-dev
libgles2-mesa-dev:
Installed: (none)
Candidate: 13.0.6-1
Version table:
13.0.6-1 500
500 http://raspbian.mirror.triple-it.nl/raspbian stretch/main armhf Packages
jdonald
Sat Dec 29, 2018 10:04 pm
I think you found a real problem.
Whether your mirror in the Netherlands or the one on raspbian.raspberrypi.org, this set says 13.0.6-1 (incorrect), while the archive.raspberrypi.org Packages says 13.0.6-1+rpi2 (correct).
That explains why others aren't hitting the problem. They typically have /etc/apt/sources/list.d/raspi.list to cover for errors in /etc/apt/sources.list. You could use the same workaround by commenting out the line in sources.list and making sure archive.raspberrypi.org (not raspbian.raspberrypi.org) takes effect when you run sudo apt update.
Question remains how we got in this precarious situation.
rmast
Sat Dec 29, 2018 10:18 pm
I tried to build libgles2-mesa from source, but the build starts swapping for lack of memory and completely stalls the desktop on my RPi3 on some tex-related stuff, so I decided not to wear out my 32GB sandisk extreme USB any further AND guess it should be crosscompiled instead.
rmast
Sat Dec 29, 2018 10:22 pm
I had some issues with the standard-mirror over wifi, so I changed it. But now with an ethernet-cable inbetween I can retry.
rmast
Sat Dec 29, 2018 10:33 pm
archive.raspberrypi.org only contains a debian tree, not raspbian, so it can't find specific rpi stuff.
DirkS
Sat Dec 29, 2018 10:49 pm
That's not correct. The name 'debian' as such is totally irrelevant.
archive.raspberrypi.org is the RPF repository. It is not a mirror or whatever of the raspbian repo.
It contains RPF specific software (modified packages, extras, etc).
It contains packages for both Pi/Arm as for Debian x86 (used for the 'Raspberry Pi desktop for PC/Mac)
So you cannot replace the Raspian repo source with the RPF repo source.
A standard RPF Raspbian image actually has both in the repository sources.
jdonald
Sat Dec 29, 2018 11:01 pm
I've built Mesa from source, and I highly recommend following Eric's straightforward instructions for cross-compiling with meson + ninja.
Well, that's only if you have some pressing reason to build it from source because it's still not a small project.
If you click the link you'll see many +rpi packages in there. I guess DirkS has a good point that if you remove one source or the other you're getting into untested territory. That non-Raspbian Debian libgles2-mesa-dev armhf package may not be intentional, but it probably isn't the only issue if you try to use the raspbian repository by itself.
It sounds like you commented out raspi.list at some point (because you thought archive contains Debian packages). What happens if you run sudo apt update with both sources in place?
rmast
Sat Dec 29, 2018 11:39 pm
Do you mean http://archive.raspbian.org/?
Sun Dec 30, 2018 12:21 am
Maybe it is time to start afresh with Raspbian Stretch and only use packages from the repositories ??
jdonald
Sun Dec 30, 2018 12:45 am
The names are no doubt confusing. Here's the first line of my /etc/apt/sources.list.d/raspi.list:
deb http://archive.raspberrypi.org/debian/ stretch main ui staging
So it seems likely that DirkS did mean archive.raspberrypi.org is the RPF repo (and it's what you're missing).
rmast
Sun Dec 30, 2018 12:55 pm
Yes! That's it! Thanks!
By the way, the Stretch-image was quite freshly Etched yesterday.
DirkS
Sun Dec 30, 2018 6:06 pm
With what?
But the answer is no anyway. I mean what I wrote, nothing else.
You seem to be intent on seeing stuff that's not there and thereby confusing yourself.
I have said what I wanted to say and will not comment on this topic anymore.
Return to “Raspberry Pi OS”
