Hamburger Pi
jessie: openarena doesn't work?
Thu Dec 27, 2018 4:18 am
When I try playing OpenArena (via apt-get) I get a entirely DIFFERENT error.
ioq3 1.36+u20161101+dfsg1-2+deb9u1/Raspbian linux-arm Aug  8 2017
----- FS_Startup -----
We are looking in the current search path:
/home/pi/.openarena/baseoa
/usr/lib/openarena/baseoa
/usr/lib/openarena/baseoa/z_oacmp-volume1-v3.pk3 (370 files)
/usr/lib/openarena/baseoa/pak6-patch088.pk3 (711 files)
/usr/lib/openarena/baseoa/pak6-patch085.pk3 (559 files)
/usr/lib/openarena/baseoa/pak6-misc.pk3 (229 files)
/usr/lib/openarena/baseoa/pak5-TA.pk3 (139 files)
/usr/lib/openarena/baseoa/pak4-textures.pk3 (1753 files)
/usr/lib/openarena/baseoa/pak2-players.pk3 (669 files)
/usr/lib/openarena/baseoa/pak2-players-mature.pk3 (231 files)
/usr/lib/openarena/baseoa/pak1-maps.pk3 (100 files)
/usr/lib/openarena/baseoa/pak0.pk3 (1042 files)
5803 files in pk3 files
execing default.cfg
couldn't exec q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
----- Client Initialization -----
Couldn't read q3history.
----- Initializing Renderer ----
Trying to load "renderer_opengl2_arm.so" from "/usr/lib/ioquake3"...
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
SDL using driver "x11"
Initializing OpenGL display
Display aspect: 1.778
...setting mode 3: 640 480
Couldn't get a visual
...WARNING: could not set the given mode (3)
----- Client Shutdown (Client fatal crashed: GLimp_Init() - could not load OpenGL subsystem) -----
RE_Shutdown( 1 )
And when I open the crash log...
execing default.cfg
QKEY found.
----- R_Init -----
RE_Shutdown( 1 )
mahjongg
Re: jessie: openarena doesn't work?
Thu Dec 27, 2018 11:54 am
No wonder, you were replying to an obsolete thread, I have split off your post from it, so you can start a new question.
And locked the thread from 2015,
Thu Dec 27, 2018 12:07 pm
execing default.cfg
QKEY found.
----- R_Init -----
RE_Shutdown( 1 )
execing default.cfg
QKEY found.
----- R_Init -----
RE_Shutdown( 1 )
Start with a fresh install of Raspbian Stretch with Desktop (Jessie is no longer current)
Update Stretch
sudo apt update
sudo apt full-upgrade
Install OpenArens
sudo apt update
sudo apt install openarena
The version in repositories is 0.8.8
Return to “Raspberry Pi OS”
