bgirardot
Booting Raspbian Wheezy via QEMU on Windows XP
Thu Nov 15, 2012 4:38 pm
I just managed to boot the latest Raspbian (2012-10-28-wheezy-raspbian.img) on my windows xp 32bit os and thought I would put the steps down here in case anyone else wants to try it.
I did not get networking working, but I have not tried yet, but it didn't work right out of the box.
Based on the directions found here:
QEMU – Emulating Raspberry Pi the easy way (Linux or Windows!)
I downloaded QEMU for Windows from here:
http://lassauge.free.fr/qemu/
I downloaded the file marked "Qemu-1.2.0-windows.zip (36M) (NEW) "
I extracted it into a folder and then downloaded this file:
http://xecdesign.com/downloads/linux-qemu/kernel-qemu
and placed it in the qemu directory
Then I downloaded the 2012-10-28-wheezy-raspbian.img file from the Raspberry downloads page and extracted it, also into the same qemu folder.
I opened the windows command line and cd'd into the qemu folder and used this command line to boot:
qemu-system-armw.exe -kernel kernel-qemu -cpu arm1176 -m 256 -M versatilepb -no-reboot -serial stdio -append "root=/dev/sda2 panic=1" -hda 2012-10-28-wheezy-raspbian.img
And it booted right up. There are some failures in the boot process, but that is to be expected I guess.
What I do not have worked out yet is the networking, any advice on that will be appreciated, but as I said, I have not really tried to get it working yet.
PIstolero
Location: paradise city, where the grass is green and the girls are pretty
Re: Booting Raspbian Wheezy via QEMU on Windows XP
Tue Nov 20, 2012 4:31 pm
Networking is working out of the box, you should access to the iNet, only problem it is like behind a NAT, see here:
http://wiki.qemu.org/Documentation/Netw ... 28SLIRP.29
If you want to access your VM, redirect the ports like here:
http://www.raspberrypi.org/phpBB3/viewt ... 85#p145885
or use a TAP device (look at the answer of Joe Schmoe in this Thread)
bgirardot
Tue Nov 20, 2012 5:13 pm
PIstolero wrote:Networking is working out of the box, you should access to the iNet, only problem it is like behind a NAT, see here:
Wow, very helpful, thank you very much.
Right after I did the install I gave the OpenVPN Tap provider a half harted try and it didn't work, but I fully intend to give it a full try soon, this will really be helpful, thank you again.
mac586
Sun Nov 25, 2012 8:26 pm
I followed this setup on Mac OSX 10.8.2 with some minor tweaks. I installed qemu using Fink; and created the directory ~/Downloads/rpi for kernel-qemu and 2012-10-28-wheezy-raspian.img
After changing directories to ~/Downloads/rpi I issued the following command:
qemu-system-arm -kernel kernel-qemu -cpu arm1176 -m 256 -M versatilepb -no-reboot -serial stdio -append "root=/dev/sda2 panic=1" -hda 2012-10-28-wheezy-raspbian.img
The image runs fine, and has networking. Very little work to check out Raspian! The display window is tiny however.
bilbo_b
Wed Jan 02, 2013 10:16 am
When i will emulate a 512MB Raspberry Pi, i have changed the line to -m 512. But with this, QEMU doenst start the image. How can i emulate a 512MB PI?
efflandt
Fri Jan 04, 2013 12:50 am
The kernel for qemu in the first link in the original post is apparently hard coded for -m 256, so at this time you cannot change it from that. However, none of that is being used for gpu_mem, so it is sort of like having a 512 MB Pi set for gpu_mem=256. If you need more memory the author suggests using a swapfile. That would require making the Raspian image larger, because there is not much free space on the original image.
themaxou
Wed Jan 16, 2013 8:37 pm
anyway to change the resolution ?
Return to “Raspberry Pi OS”
