plugwash
chromiium 22 packages available for testing
Thu Nov 15, 2012 12:48 am
I don't have a Pi handy at the moment and I would like to get the chromium 22 packages i've just built tested before putting them into raspbian.
The packages are at http://plugwash.raspbian.org/chromium22/ . Please test them and report back any regressions you've noticed compared to the packages currently in raspbian.
plugwash
Re: chromiium 22 packages available for testing
Thu Nov 22, 2012 7:55 pm
405 views and no comments positive or negative.
Come on guys give me some feedback.
hexelpdkk
Thu Nov 22, 2012 8:15 pm
I just downloaded and installed all the non dbg packages, and I get an instant segmentation fault if I try to run chromium-browser.
What can I do to provide more info?
hexelpdkk
Thu Nov 22, 2012 9:46 pm
Got it to core dump, and have installed the dbg packages, but gdb seems to sit there forever (well, > 5 mins anyway). Swapped to my 512Mb pi, but same symptoms on both chromium and gdb.
Wendo
Fri Nov 23, 2012 5:05 am
Instant segfault here too on a rev1 pi with a well used raspbian install
Cloudcentric
Sat Dec 08, 2012 2:26 pm
Segmentation fault:
[email protected]:/home/pi# dpkg -i chromium22.deb
dpkg: error: dpkg status database is locked by another process
(Reading database ... 73980 files and directories currently installed.)
Preparing to replace chromium 20.0.1132.57~r145807-1+rpi1 (using chromium22.deb) ...
Unpacking replacement chromium ...
Setting up chromium (22.0.1229.94~r161065-3+rpi1) ...
Installing new version of config file /etc/chromium/master_preferences ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for man-db ...
Processing triggers for menu ...
Processing triggers for desktop-file-utils ...
[email protected]:/home/pi# chromium22
bash: chromium22: command not found
Segmentation fault
I know everything about nothing"
andruoid
Thu Dec 27, 2012 4:47 am
I installed Chromium (Version 20.0.1132.57 Debian wheezy/sid (145807)) on Rasberian.
Apart from using more RAM (than Netsurf and Midori) and a tad slower it has been fine. I went back to 64MB for video (from 128MB) and that seems to have sped things up a bit. The only page that has given me issues is Facebook but that happens 3/10 times. I hit wait and it reloads np.
As mentioned it is a slower browser but at least it displays pages properly :)
Thu Dec 27, 2012 10:05 am
andruoid wrote:I installed Chromium (Version 20.0.1132.57 Debian wheezy/sid (145807)) on Rasberian.
Although worthwhile information, the OP was talking about v22. Any chance you can try that?
andruoid
Thu Dec 27, 2012 2:39 pm
jamesh wrote:Although worthwhile information, the OP was talking about v22. Any chance you can try that?
I'll give it a try after work today :) ...my mistake about the version was due to TOD; turkey overdose.
plugwash
Sat Dec 29, 2012 2:42 am
I managed to reproduce the issue and get a backtrace but it wasn't a very helpful backtrace.
(gdb) bt
#0 0x001face0 in ?? ()
#1 0x42d6c06c in __libc_csu_init ()
#2 0x44f047b0 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Cannot access memory at address 0x0
#3 0x44f047b0 in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
On hexxeh's suggestion i've attempted to disable "hardening" We will see how that works out.
plugwash
Fri Jan 11, 2013 8:34 am
Ok i've just posted a new set of packages at http://plugwash.raspbian.org/chromium22/ can someone test them out.
Cloudcentric
Fri Jan 11, 2013 12:36 pm
plugwash wrote:Ok i've just posted a new set of packages at http://plugwash.raspbian.org/chromium22/ can someone test them out.
Just an observation is not Chromium at version 25 ?
Regards version 22.0.1229.94 Debian 7.0 (161065) it installs OK with no errors and is listed in the Menu and launches OK, but has very high memory usage, and therefore a lot slower than Midori.
I was able to Synch my Google Account with no issues.
I was able to run the Chrome Extensions Jolicloud and Freecell Apps, but GlideOS wanted the 'real' Flash Player' not gnash
So yes apart from the memory issue it appears to be running AOK and a great update!
http://html5test.com
your browser scores 373 AND 2 BONUS POINTS out of a total of 500 points
You are using Chrome 22 on Linux
http://www.youtube.com/html5
Your browser does not support HTML5 video with our site
Return to “Raspbian”
