aristosv
raspbian remove all the text shown during the boot up process
Wed Dec 05, 2018 9:12 pm
I am using Raspbian Stretch Lite and I want to remove all the text scrolling during the boot up process. I've googled how to do this and found various articles indicating that I should modify /boot/cmdline.txt, redirect the console to tty3 and configure loglevel=3. I also tried dmesg --console-off in /etc/rc.local.
These suggestions haven't worked for me, I can still see the full text during the boot up process.
Also this forum post provides a zip file containing files to be overwritten in Raspbian to hide all the text during boot. But I would really prefer not to overwrite system files, not really knowing how they will affect it.
Any suggestions on how to achieve this?
aristosv
Re: raspbian remove all the text shown during the boot up process
Thu Dec 06, 2018 8:35 am
eventually I found it. This gave me a completely blank screen.
echo hide raspberry pi icons
sudo sed -i "1 s|$| logo.nologo quiet splash|" /boot/cmdline.txt
echo hide boot messages
sudo sed -i "1 s|$| quiet splash|" /boot/cmdline.txt
echo disable login prompt
sudo systemctl disable getty@tty1.service
echo hide blinking cursor
sudo sed -i "1 s|$| vt.global_cursor_default=0|" /boot/cmdline.txt
echo hide undervoltage message
sudo sed -i "1 s|$| loglevel=1|" /boot/cmdline.txt
echo hide undervoltage lightning bolt icon
sudo sed -i '1 i\avoid_warnings=1' /boot/config.txt
DirkS
Thu Dec 06, 2018 8:39 am
If you think it's necessary to hide the undervoltage indicators than maybe it's time to check your power supply...
aristosv
Thu Dec 06, 2018 8:42 am
I understand. It's just a test-bed though. The production Pi's will have at least 3 amps power supplies.
Return to “Raspberry Pi OS”
