Alvaro
Setting screen blanking on every boot
Tue Nov 13, 2012 6:31 pm
When I am watching a movie, I don't want to wait for 10 minutes until the borders go black, so I have set the time to 60 seconds with the following command (as root):
xset s 60
What is the easiest way to automatically run this command on every boot?
k4gbb
Re: Setting screen blanking on every boot
Tue Nov 13, 2012 9:57 pm
Try placing the command in /etc/rc.local
The Grass may be greener on the other side of the fence, but it still has to be mowed.
Alvaro
Wed Nov 14, 2012 6:37 pm
That didn't work.
root@raspberrypi:~# cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
xset s 60
exit 0
Anything wrong with what I did?
jojopi
Wed Nov 14, 2012 6:56 pm
xset needs to be run after X starts, and from inside the X environment. So you can not put it in rc.local.
See the threads about "disable screen blanking", but use "60" instead of "off".
Alvaro
Thu Nov 15, 2012 4:27 pm
I think I have tried them all. The only thing that works is xset, and I have to type that manually. Always. No big deal since I only reboot on kernel upgrades, but still...
Return to “Raspberry Pi OS”
