sukakuu
error when update repo
Thu Nov 01, 2018 7:01 am
hello sir
why i always get error when update repository ?
i want to install All in one printer Epson L3150
for printer it's OK.. but for scanner always error when update repo
like this:
root@raspberrypi:/home/pi# apt-get update
Hit http://archive.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Get:1 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
Get:2 http://archive.raspbian.org jessie/main Sources [7,761 kB]
Hit http://archive.raspberrypi.org jessie/main Sources
Err http://archive.raspberrypi.org jessie/ui Sources
Hit http://archive.raspberrypi.org jessie/ui Sources
Get:3 http://archive.raspbian.org jessie/contrib Sources [64.5 kB]
Get:4 http://archive.raspbian.org jessie/non-free Sources [113 kB]
Get:5 http://archive.raspbian.org jessie/rpi Sources [1,132 B]
Fetched 7,955 kB in 36s (221 kB/s)
W: Failed to fetch http://mirrordirector.raspbian.org/rasp ... /InRelease Unable to find expected entry 'main/binary-amd64/Packages' in Release file (Wrong sources.list entry or malformed file)
E: Some index files failed to download. They have been ignored, or old ones used instead.
/etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
any idea ?
thanks before
wh7qq
Re: error when update repo
Thu Nov 01, 2018 7:19 pm
Jessie is out of date and has been replaced by Stretch. Updates to Jessie may get hung up on the Stretch repos. Download the 10-2018 Raspbian_latest and it updates fine.
DirkS
Thu Nov 01, 2018 7:25 pm
There's a reference to amd64 packages here and that's not available.
Apart from the standard sources.list you listed are there any other list files in directory /etc/apt/sources.list.d ?
Can you post the contents?
sukakuu
Fri Nov 02, 2018 2:06 am
helloo sir, thank for your respons
so, must upgrade to Stretch ? :|
sukakuu
Fri Nov 02, 2018 2:07 am
hello sir', still default for /etc/apt/sources.list.d
like this
#deb http://archive.raspberrypi.org/debian/ jessie main ui
deb-src http://archive.raspberrypi.org/debian/ jessie main ui
DirkS
Fri Nov 02, 2018 8:06 pm
like this
That is not the default. The first line should not be commented out. And I'm fairly sure the last line is commented out by default.
Your RPF specific packages will not be updated.
Fri Nov 02, 2018 9:56 pm
To be blunt about this the only way forward is to start with a fresh install of Raspbian Stretch with Desktop:
https://www.raspberrypi.org/downloads/raspbian/
Thinking outside the box is better than burying your head in the sand...
wh7qq
Fri Nov 02, 2018 10:43 pm
Amen!
code_exec
Sat Nov 03, 2018 7:34 am
"Unable to find expected entry 'main/binary-amd64/Packages' in Release file"
Raspbian uses the ARMHF architecture, since this is the architecture that all RPi's are compatible with. However, no Pi is compatible with AMD64 (also known as x64) programs. You most likely added AMD64 as an architecture for dpkg to attempt to get packages for. To remove AMD64 from the list of dpkg architectures, run:
sudo dpkg --remove-architecture amd64
Then, try running sudo apt update again.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
sukakuu
Mon Nov 05, 2018 1:58 am
thank for your respon..
this result
root@raspberrypi:~# dpkg --remove-architecture amd64
dpkg: error: cannot remove architecture 'amd64' currently in use by the database
root@raspberrypi:~#
sukakuu
Mon Nov 05, 2018 3:54 am
like this
oooh ok
you have default sources.list for jessie sir?
DirkS
Mon Nov 05, 2018 11:42 am
Read my earlier response. It's also in the quote above.
But here it is again: uncomment the first line and comment out the last line
sukakuu
Tue Nov 06, 2018 4:35 am
ok, like this
#deb-src http://archive.raspberrypi.org/debian/ jessie main ui
for result
root@raspberrypi:~# apt-get update
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Fetched 22.9 kB in 14s (1,632 B/s)
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease Unable to find expected entry 'main/binary-amd64/Packages' in Release file (Wrong sources.list entry or malformed file)
root@raspberrypi:~#
how about this sir?
Tue Nov 06, 2018 8:13 am
ok, like this
for result
root@raspberrypi:~#
how about this sir?
viewtopic.php?f=66&t=225987#p1387453
sukakuu
Tue Nov 06, 2018 8:53 am
ok, like this
for result
root@raspberrypi:~#
how about this sir?
that's final sollution? :|
DirkS
Tue Nov 06, 2018 8:55 am
root@raspberrypi:~#
how about this sir?
Did you at some point (try to) install an x86 / amd64 package?
What is the output of
dpkg-query -l | grep amd64
sukakuu
Mon Nov 12, 2018 1:13 am
root@raspberrypi:~#
how about this sir?
result
root@raspberrypi:~# dpkg-query -l | grep amd64
iU epson-inkjet-printer-201207w 1.0.0-1lsb3.2 amd64 EPSON L110/210/300/350/355/550/555 Series - Epson Inkjet Printer Driver
iU epson-printer-utility 1.0.2-1lsb3.2 amd64 Epson Printer Utility for Linux
iU libatkmm-1.6-1v5:amd64 2.24.2-3 amd64 C++ wrappers for ATK accessibility toolkit (shared libraries)
DirkS
Mon Nov 12, 2018 11:55 am
You seem to have a habit of giving partial answers...
But it looks like you tried to install some amd64 programs (drivers) at some point. To remove them I would try the following:
Make a backup of your SD card and then run
sudo apt-get remove ".*:amd64"
Return to “Raspberry Pi OS”
