develop-cr
RTC module not working ds1307
Wed Oct 17, 2018 6:31 am
https://learn.adafruit.com/adding-a-rea ... i/overview I did it successfully according to the guide on the line. If I turn it off and open it in 10 minutes, the clock is right. But if it stays closed for more than 10 minutes, it doesn't show the correct time.How do I solve my problem? my operating system, stretch.
gordon77
Re: RTC module not working ds1307
Wed Oct 17, 2018 3:12 pm
Here's what I did with my ds1307, l found it on this forum somewhere.
add dtoverlay=i2c-rtc,ds1307 to /boot/config.txt
in /lib/udev/hwclock-set put # in front of these lines
if [-e /run/systemd/system ]; then
exit
fi
and # in front of the 2 lines containing --systz
reboot your pi
set the clock with sudo date -s "16 Oct 2018 17:12:00" using the correct date and time
sudo hwclock -w
sudo hwclock -r
develop-cr
Thu Oct 18, 2018 12:46 pm
Gordon, thank you for the answer. but my problem is not solved.
Thu Oct 18, 2018 4:48 pm
Do you get any messages from the kernel?
[   42.133300] rtc-ds1307 1-0068: registered as rtc0
Note:Having anything remotely humorous in your signature is completely banned on this forum.
develop-cr
Fri Oct 19, 2018 5:42 am
no, there's no kernel message like that.
Fri Oct 19, 2018 5:35 pm
Then your hardware is either broken or not connected correctly.
Return to “Raspbian”
