RonR
vcgencmd get_throttled
Tue Oct 16, 2018 1:20 am
The only documentation I've found for the command 'vcgencmd get_throttled' is:
This returns a hex number in which the following bits may be set:
0: under-voltage
1: arm frequency capped
2: currently throttled
16: under-voltage has occurred
17: arm frequency capped has occurred
18: throttling has occurred
On a RPi 3B+ running 2018-10-09-raspbian-stretch-lite.img, I'm seeing the occasional 'throttled=0x80000' and 'throttled=0x80008'.
What do these bits represent?
hippy
Re: vcgencmd get_throttled
Tue Oct 16, 2018 10:46 am
My guess would be that the bits reflect the new throttling option the P3B+ has which kicks in at 60C before the usual throttling kicks in at 70C -
https://www.raspberrypi.org/forums/view ... p?t=217056
You could maybe setup a script which reports temperature and throttled values to see if there's any correlation. Or just wait for 'an official answer'.
Tue Oct 16, 2018 1:52 pm
Yes, that new bit is the SOFT_TEMP_LIMIT bit.
0x80000 means its has been set in the past, 0x8 means it is set at the moment (ie happening)
Tue Oct 16, 2018 2:14 pm
There a vcgencmd doc I've been working on that has the full table, see here
https://github.com/raspberrypi/document ... cgencmd.md
DrYak
Updated linky
Tue Jan 22, 2019 11:37 am
For those like my who end up here from google, here is the new updated link:
(I managed to find it from there)
Tue Jan 22, 2019 1:12 pm
Ah, yes, I've just updated the PR (in fact done a new one) so my link above no longer works.
iurly
Wed Jun 05, 2019 10:39 am
Could anyone please elaborate on the actual meaning of these bits?
- "Under-voltage" is pretty much self-explaining
- "Throttling" looks like some countermeasure to overcome undervoltage, and most of the time I've seen together with under-voltage
- "Arm frequency capped" I've only seen a few times and I can't figure out what the relation with above two is
Any ideas?
Thank you!
Wed Jun 05, 2019 11:34 am
Any ideas?
Thank you!
https://www.raspberrypi.org/documentati ... agement.md
iurly
Wed Jun 05, 2019 12:14 pm
Thank you for the pointer James.
Still, I don't get what the "arm frequency capped" represents.
Is it the consequence of some over-temperature situation (and therefore unrelated to under-voltage)?
Wed Jun 05, 2019 12:43 pm
Arm frequency is dropped when the cores are too hot, and also I believe when voltage drops.
Return to “Raspbian”
