gkreidl
Latest omxplayer builds for jessie and stretch
Fri Oct 05, 2018 7:14 am
Recently the omxplayer sources by popcornmix got some nice new additions, which I plan to use in the next releases of my kweb suite (omxplayerGUI and ytdl-server) for Raspbian Stretch and Jessie. Two new dbus commands (SetLayer and OpenUri) allow to modify the video layer and the video source at run time.
In the past you could always get new builds from omxplayer.sconde.net but the latest version there is from 30/01/2017.
So I built new versions for both Stretch and Jessie and made them available for download:
Jessie Version
Stretch Version
A few notes about the Stretch version:
The omxplayer version in the Foundation repository is not sourced from popcornmix any more, but from a fork by XECDesign. This version does not use its own ffmpeg libraries but relies on the ffmpeg system libraries. My package uses the old method of including its own ffmpeg libraries because omxplayer is now built against ffmpeg 3.3, while the system libraries are version 3.2. But I've also used the version naming convention introduced by XECDesign to make sure that it is recognized as a newer version.
Minimal Kiosk Browser (kweb)
k-pi
Re: Latest omxplayer builds
Fri Oct 05, 2018 9:33 am
Thanks, downloaded the Stretch version, will give it a try next time I'm using my RPi3B setup. 8-)
yan
Sat Oct 13, 2018 7:59 am
Thank you!
deanresin
Sun Dec 02, 2018 8:13 am
After installing on Jessie I get the error...
/usr/bin/omxplayer.bin: error while loading shared libraries: libva-x11.so.1: cannot open shared object file: No such file or directory
when trying to run omxplayer.
gkreidl
Sun Dec 02, 2018 1:42 pm
Perhaps a dependency of the internal ffmpeg libraries.
Install libva-x11-1
deanresin
Mon Dec 03, 2018 5:19 am
Install libva-x11-2
How do I install libva-x11-2?
Does this latest build of omxplayer use an internal ffmpeg or the Raspbian ffmpeg?
gkreidl
Mon Dec 03, 2018 8:10 am
Install libva-x11-2
Sorry for the typo: it must be libva-x11-1. Install it with
sudo apt-get install libva-x11-1.
This build uses an internal ffmpeg version (as all older versions).
BTW, the Foundation published a new version containing the latest changes (Stretch).
Return to “Raspbian”
