Having trouble watching videos in VLC?
Posted: Tue Sep 18, 2018 3:48 pm
by k-pi
So was I, so I braved it, & installed Kodi, it has a weird interface, but it works, I can now watch videos on my desktop RPi3B setup. :D
If you follow suit, be aware that it starts up at full volume, needs altering pronto. ;)
Re: Having trouble watching videos in VLC?
Posted: Tue Sep 18, 2018 6:10 pm
by topguy
Yes, VLC dont use HW decoding of video so if has mediocre performance, there are 100+ threads about it on the forum.
That is why we have omxplayer:
https://www.raspberrypi.org/documentati ... /README.md ( this page should go I think.. too brief )
https://www.raspberrypi.org/documentati ... xplayer.md
Not bashing Kodi here, its just a bit of overkill if you just want to watch some video.
Posted: Tue Sep 18, 2018 6:34 pm
by k-pi
I had noticed mention of this OMXplayer, but I thought it must be something special, as in special purpose software. :roll: :o
So, but those links, it is something similar to mplayer/mpv, which I looked for but didn't find. ;)
I shall give it a try out for future reference, or maybe as my replacement, as I'm not very keen on the interface of Kodi. :D
Thanks for taking the time to post. 8-)
Posted: Tue Sep 18, 2018 6:37 pm
by DirkS
I shall install it, & give it a try out for future reference, or maybe as my replacement, as I'm not very keen on the interface of Kodi. :D
You don't need to install Kodi to use omxplayer.
You can use it from the command line. And there's also @gkreidl's omxplayergui
Posted: Tue Sep 18, 2018 7:07 pm
by topguy
"Special" as in the official optimized mediaplayer from the people that make the Pi ;-)
Its basically a commanline tool just like "mplayer" and "mpv". ( Which both are also installable with a simple "apt-get install" btw. but they have the same problem as VLC. )
As someone above posted, you can find gui for OMXplayer too.
Posted: Wed Sep 19, 2018 7:51 am
by fruitoftheloom
omxplayerGUI see:
https://www.raspberrypi.org/forums/view ... hp?t=40860
Posted: Wed Sep 19, 2018 8:45 am
by k-pi
So - I gave it a go last night - I had to kill it by switching off mains power! :shock:
It wouldn't respond to the keyboard commands - & I really hate pulling power on a computer.
So what went wrong?
P.S. Again, started out at full volume, beware of that, don't wear headphones. 8-)
Posted: Wed Sep 19, 2018 8:56 am
by k-pi
From using omxplayer at the command line, the help screen showed I should use ./omxplayer -p -o hdmi test.mkv
But having ./ at the front was obviously wrong, as it wouldn't start, so I went with omxplayer -p -o hdmi my.mp4
This started playing OK, but didn't respond to the keyboard.
Posted: Wed Sep 19, 2018 9:02 am
by jamesh
Here are the official docs for omxplayer
Posted: Wed Sep 19, 2018 9:07 am
by k-pi
Thanks jamesh - I already have it bookmarked. ;)
(I think starting a program with volume at 100% is bad practice though.)
--vol n                 set initial volume in millibels
What's a millibel?
Posted: Wed Sep 19, 2018 9:19 am
by k-pi
Hmm, so what this thread has shown so far, is that VLC, mplayer, & mpv are all 'broken' as regards to playing videos, (their main purpose). :lol:
This is a sad situation. :mrgreen:
Posted: Wed Sep 19, 2018 9:22 am
by fruitoftheloom
They are not broken, they have not been compiled with Hardware Acceleration.
Semantics :roll:
Posted: Wed Sep 19, 2018 9:38 am
by topguy
- "./" is for when you have a program/script in current directory you want to use.
- What is special about your keyboard ? Are you doing this over SSH or not ?
- Most medialplayers I have used over the last 15 years start with 100% volume, turn down your amplifier/screen instead.
Posted: Wed Sep 19, 2018 9:53 am
by LTolledo
Have not used VLC due to its known problems.
Tried omxplayer from time to time when I want to watch and browse at the same time.
Keyboard controls for omxplayer work on my setup.
And yes... I set the amp volume first before playing any playable media on omxplayer.....
If there is already a compiled version of VLC (for raspbian) in the repository then that is the time I'll try it again...
Posted: Wed Sep 19, 2018 10:32 am
by k-pi
I know ./ is for when you run from your directory, but that's what it said! :D
Keyboard is a standard USB, nothing at all unusual about it, omxplayer just didn't respond to it! :o
P.S. Re sound level, my distro is & was set at 20%, this program just took over my sound card at full volume! :x
Posted: Wed Sep 19, 2018 10:48 am
by topguy
You did use the "-p" audio passtrough option after all, which means send digital sound directly to the HDMI without any modification.
Posted: Wed Sep 19, 2018 3:12 pm
by k-pi
That being the case, it wasn't clear from their sample command that it would bypass the system it was running on. :shock:
Could do with clearer info.
(Just in case you think I'm a newbie, I'm not, I've been using Linux & BSD since 1999.)
