777funk
FSTAB to automount NFS Share - No go... any ideas?? update: sudo mount -a WILL mount the FSTAB
Mon Sep 17, 2018 11:57 pm
Hereś what I have in my FSTAB file:
192.168.1.249:/home/n/Videos /mnt/nfs nfs defaults,user,exec 0 0
I can manually mount the share by:
sudo mount 192.168.1.249:/home/n/Videos/ /mnt/nfs
But I hate to do that every time I log into the pi
Is there something I have wrong in my FSTAB? It doesn´t seem to go.
777funk
Re: FSTAB to automount NFS Share - No go... any ideas?? update: sudo mount -a WILL mount the FSTAB
Tue Sep 18, 2018 11:59 am
To update my own thread... if I run a:
sudo mount -a
It loads up just fine. So something at boot is causing the issue.
It'd be nice to have this automatic as intended.
scruss
Tue Sep 18, 2018 12:24 pm
try adding
nfsvers=3
to the options field.
Pronouns: he/him
DirkS
Tue Sep 18, 2018 12:25 pm
Looks like the network is not yet ready when fstab is processed.
You could try to activate 'wait for network' in raspi-config
Alternatively you could create a systemd mount file. That makes it easier to wait for the network to be up before mounting the share.
There are examples for the systemd file here on the forum.
DirkS
Tue Sep 18, 2018 12:26 pm
try adding
nfsvers=3
Would that make a difference? 'mount -a' works, so I would assume it uses the options that are in fstab.
RaTTuS
Contact: Twitter YouTube
Tue Sep 18, 2018 1:01 pm
https://www.raspberrypi.org/forums/view ... 0#p1367168 what Dirks said...
as the network is not up use a systemd mounnter
Covfefe
777funk
Tue Sep 18, 2018 2:48 pm
I forgot to mention that I had also checked the "wait for network" box in raspi-config and that didn't do the trick. I was 99% sure it would have since the problem seems to be with timing during boot.
epoch1970
Tue Sep 18, 2018 7:09 pm
Systemd reads fstab at boot and generates mount "units" that are all run in parallel. Which, not unexpectedly, causes issues.
You'll have to use systemd's x-systemd-automount option (and others) to mount that share.
scruss
Tue Sep 18, 2018 8:59 pm
Makes all the difference on my installations.
It's probably redundant, but you can also add the _netdev option to signal the FS needs the network. NFS mounts automatically wait for the network, so you probably don't really need it.
Pronouns: he/him
777funk
Wed Sep 19, 2018 7:25 pm
Solved it from within the fstab by adding the following into the fstab options settings:
noauto,x-systemd.automount
So it looked like this when I was done...
192.168.1.2:/home/n/Videos/ /mnt/nfs   nfs defaults,user,exec,noauto,x-systemd.automount       0 0
and it works.
thisisalloneword
Tue Mar 17, 2020 6:08 pm
I am running into the exact same issue. I am trying to share a folder on a pi 3b+ with a pi 4. My /etc/fstab on the pi4 looks like:
# 192.168.1.51:/var/www/html/share /var/www/html/share nfs tcp,hard,intr,rsize=32768,wsize=32768 0 0
192.168.1.51:/var/www/html/share /var/www/html/share nfs defaults,user,exec,noauto,x-systemd.automount 0 0
If I uncomment out the first line and comment out the second line AND enable "wait for networking on boot", then it works. But is there any danger in enabling "Wait for network on boot"? What if there is no network?
ronnih
Thu Mar 19, 2020 8:48 am
Hi thisisalloneword,
I use the option "wait for networking on boot" since one year without problems. If no network available the system try first to mount the NFS share and after a short time out the system boot goes on.
My line for NFS share in the fstab:
fileserver:/srv/nfs/USBDisk/NFSshare	/home/tux/NFSshare  nfs4  rw 0 0
https://techguru.lima-city.de
martyweb
Wed Jul 15, 2020 1:08 pm
try adding
nfsvers=3
This worked great for me, thanks!
Return to “Raspberry Pi OS”
