HermannSW
"con2fbmap 1 1" in "/etc/rc.local" only after 66 seconds, better place?
Tue Sep 11, 2018 9:49 am
After powering Pi ZeroW the SPI display gets black (initialized) after 21 seconds.
But only after 66 seconds the last boot messages in console get displayed.
I am searching where I have to do "con2fbmap 1 1" better than in "/etc/rc.local" (66s).
I have this in "/etc/modules-load.d/fbtft.conf":
spi-bcm2835
fbtft_device
And this in "/etc/modprobe.d/fbtft.conf":
options fbtft_device name=rpi-display gpios=reset:25,dc:24,led:27 rotate=90
Both together initialize display after 21 seconds which is OK.
I appended this to "/etc/rc.local":
tail --bytes 153600 /home/pi/fb1.565.bmp> /dev/fb1
sleep 1
con2fbmap 1 1
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw      https://github.com/Hermann-SW/userland
https://github.com/Hermann-SW/wireless-control-Eachine-E52-drone      https://twitter.com/HermannSW
DirkS
Re: "con2fbmap 1 1" in "/etc/rc.local" only after 66 seconds, better place?
Tue Sep 11, 2018 11:05 am
Put it on the kernel command line?
Add fbcon=map10 at the end of the line in that file
See e.g. https://www.kernel.org/doc/Documentation/fb/fbcon.txt for more info
https://github.com/notro/fbtft/wiki/Boot-console
HermannSW
Tue Sep 11, 2018 12:41 pm
Thank you, appending "fbcon=map:10" to /boot/cmdline.txt did the trick!
Since that maps tty1 to fb1 at the start, console output starts when display gets initialized after 22 seconds.
This is very useful since now I can see everything after 22 seconds, including file system check that increases boot time.
Return to “Raspbian”
