Tichun
Fixed display power management
Fri Aug 31, 2018 4:50 pm
Due to Raspberry Pi's peculiarity, default linux DPMS doesn't turn the screen off after idle time, it only fills it with a dark color.
That is solved when using the unfinished OpenGL driver. But that isn't the only way!
Minimal C code
#include <X11/extensions/scrnsaver.h>
#include <stdio.h>
int main(void) {
    Display *dpy = XOpenDisplay(NULL);
    if (!dpy) {
        return(1);
    XScreenSaverInfo *info = XScreenSaverAllocInfo();
    XScreenSaverQueryInfo(dpy, DefaultRootWindow(dpy), info);
    printf("%u\n", info->idle);
        return(0);
And a script to make it all work
#!/bin/bash
idle=false
idleAfter=480000
while true; do
          idleTimeMillis=$(./getIdle)
              if [[ $idle = false && $idleTimeMillis -gt $idleAfter ]] ; then
                              idle=true
                              vcgencmd display_power 0
                fi
	if [[ $idle = true && $idleTimeMillis -lt $idleAfter ]] ; then
		idle=false
		vcgencmd display_power 1
	fi
                sleep 4      # polling interval
                done
Source of information
I hope something like this gets into Raspbian.
klricks
Re: Fixed display power management
Sat Sep 01, 2018 1:19 am
Adding this to /boot/config.txt will automatically turn off video output on blanking timeout.
hdmi_blanking=1
On blanking my TV will show no signal message for about 20 min then turn off. Once the screen has gone off it won't wake up again unless I press the ON button. While the no signal message is displayed the RPi screen will wake up as expected.
I also get the same behavior when using vcgencmd display_power 0 from command line.... After the 20 min screen off, issuing vcgencmd display_power 1 will not turn on the display without also pressing the power ON button. (Tested by VNC connection).
Return to “Raspberry Pi OS”
