Bremenpl
Drivers for 7 inch waveshare touc screen?
Wed Aug 29, 2018 2:35 pm
Hello there,
I have just downloaded the latest rasbian. Turned it on and updated. Connected this creen:
https://www.waveshare.com/wiki/7inch_HDMI_LCD_(B)
After applying this to config.txt the screen resolution is correct:
max_usb_current=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
hdmi_drive=1
The problem is that the touch doesnt work at all. The screen is visible:
[email protected]:~ $ lsusb
Bus 001 Device 006: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 005: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 004: ID 0eef:0005 D-WAV Scientific Co., Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
I followed this guide to install the driver: https://github.com/derekhe/waveshare-7i ... een-driver
But id didnt help. What could be the case? I would appreciate all help.
http://lprzenioslo.zut.edu.pl
Re: Drivers for 7 inch waveshare touc screen?
Wed Aug 29, 2018 2:43 pm
Hello there,
max_usb_current=1
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
Tested using official image: 2015-05-05-raspbian-wheezy.img
The link is 2 generations of Raspbian out of date.
Stupid question but did you plug in the USB Cable required for Touch ??
https://www.waveshare.com/product/7inch-HDMI-LCD-B.htm
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
DirkS
Wed Aug 29, 2018 3:08 pm
Must be; the device is visible:
That's basically an eGalax panel.
I have not checked it, but I'm pretty sure this device is supported by default in Raspbian.
Bremenpl
Wed Aug 29, 2018 3:21 pm
Thabks for answers. The touch should work, as it was working on the previous rpi image on an sd card I found (not sure what version, some old one). Now I installed fresh one and there is bo touch :/.
DirkS
Wed Aug 29, 2018 3:23 pm
Normally you would have to configure / calibrate the panel. Have you done that?
Bremenpl
Wed Aug 29, 2018 3:25 pm
I did not, since the touch doesnt work at all, I thought there is no need for that. Am I wrong?
Return to “Raspbian”
