ksharindam
rebuild.sh in hello_pi failed to build hello_mmal_encode
Wed Aug 22, 2018 11:21 am
I was running rebuild.sh in hello_pi to compile the example sources.
but it failed to build hello_mmal_encode.
cc -o hello_mmal_encode.bin -Wl,--whole-archive mmal_encode.o -lmmal -lmmal_core -lmmal_components -lmmal_util -lmmal_vc_client --no-as-needed -L/opt/vc/lib/ -lbrcmGLESv2 -lbrcmEGL -lopenmaxil -lbcm_host -lvcos -lvchiq_arm -lpthread -lrt -lm -L/opt/vc/src/hello_pi/libs/ilclient -L/opt/vc/src/hello_pi/libs/vgfont -Wl,--no-whole-archive -rdynamic
cc: error: unrecognized command line option ‘--no-as-needed’; did you mean ‘--no-assert’?
../Makefile.include:19: recipe for target 'hello_mmal_encode.bin' failed
make[1]: *** [hello_mmal_encode.bin] Error 1
rm mmal_encode.o
make[1]: Leaving directory '/opt/vc/src/hello_pi/hello_mmal_encode'
Makefile:10: recipe for target 'apps' failed
make: *** [apps] Error 2
It seems that --no-as-needed is not recognized by linker.
The package maintainer should fix it.
DirkS
Re: rebuild.sh in hello_pi failed to build hello_mmal_encode
Wed Aug 22, 2018 11:37 am
You should open an issue on the userland github repo: https://github.com/raspberrypi/userland/issues
warmbiscuit
Tue Aug 28, 2018 11:39 pm
I'm having the exact same issue. I can get the Hello_World example to run in the console, but if I try to run anything else, the console essentially freezes.
ksharindam
Thu Aug 30, 2018 6:17 am
I can successfully run all of the example binaries. The console does not freeze.
DirkS
Thu Aug 30, 2018 7:59 am
Sorry, but how can this be exactly the same issue..
OP gets an error while building a program and you have problems running some programs.
Please create a new topic and describe exactly the problems you have. Include information such as model Pi, OS + version, which programs you have problems with, etc
Return to “Raspbian”
