mohamedhamad
Raspberry pi display sleep time of touch screen
Thu Aug 16, 2018 3:37 am
I’m trying to figure out how to set the display sleep setting on my pi with the official touch screen to something like 20-30s.
I’ve created a magic mirror setup, n I want it to turn on the display on screen tap, n then turn off after 20-30s.
I tried installing XScreenSaver but that didn’t work n after setting it to 1min to turn off the display, nothing happened.
All message boards n threads pertain to never turning off the display, but want the display to turn off quickly.
How can I do this?
klricks
Re: Raspberry pi display sleep time of touch screen
Thu Aug 16, 2018 1:25 pm
How can I do this?
Does the default 10 minute screen blanking work with the official touchscreen? If so the try xset commands.
xset s 30
This works with HDMI screens but not sure about official touchscreen?
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
mohamedhamad
Fri Aug 17, 2018 3:12 am
Thanks for the suggestion, just tried the command and got this message
xset: unable to open display “”
mohamedhamad
Fri Aug 17, 2018 3:17 am
Ok, found out I had to set the display first with
export DISPLAY=:0
mohamedhamad
Fri Aug 17, 2018 4:01 am
Looks like that did the trick! Thank you for your help!
klricks
Fri Aug 17, 2018 5:24 am
Note that you will need to run the xset command after each boot. One way to to that is to put the command in autostart.
Return to “Raspbian”
