Bad checksum after apt update
Posted: Wed Aug 15, 2018 10:04 pm
by drail
Hello, I have a problem with my pi0w, when I type him
sudo apt update
in response i receive this:
[email protected]:/etc/apt/sources.list.d $ sudo apt update
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Get:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease [15.0 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian stretch/main armhf Packages [11.7 MB]
Err:3 http://mirrordirector.raspbian.org/raspbian stretch/main armhf Packages
  Hash Sum mismatch
  Hashes of expected file:
   - Filesize:11656360 [weak]
   - SHA256:ecefaf7241bc5cf6a5722dcdc7defffe51cf2530c36b77160871d0d58b1e44de
   - SHA1:bc76e66d141345e308f3f3f80aca4ce8f712f626 [weak]
   - MD5Sum:344f56666ae178acd0f9b203bd962f2f [weak]
  Hashes of received file:
   - SHA256:71f99e976a573deb3d5706702ad2aa79cfac866207a8735d3805577863b3c2ee
   - SHA1:a3b32d88c258cb4f570a974e1c9eaab8d3f26e61 [weak]
   - MD5Sum:b4ca31d39272b7ea498e581d76e1e4ed [weak]
   - Filesize:623825 [weak]
  Last modification reported: Wed, 15 Aug 2018 17:04:34 +0000
  Release file created at: Wed, 15 Aug 2018 17:09:43 +0000
Get:4 http://mirrordirector.raspbian.org/raspbian stretch/contrib armhf Packages [56.9 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian stretch/non-free armhf Packages [95.2 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian stretch/rpi armhf Packages [1360 B]
Get:7 http://mirrordirector.raspbian.org/raspbian stretch/firmware armhf Packages [1232 B]
Fetched 639 kB in 5s (126 kB/s)
Reading package lists... Done
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/stretch/main/binary-armhf/Packages.xz  Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
I tried apt clean, but it's not working.
I can ping domains, so connection is alright. Date is correct too.
Do you have any idea how to fix it?
Re: Bad checksum after apt update
Posted: Thu Aug 16, 2018 6:19 am
by rpdom
Free space on your SD card? The downloaded file sizes are smaller than the expected size.
What does the command
df -h /
show?
Also, what size of card are you using?
Posted: Thu Aug 16, 2018 1:53 pm
by awrc
I'm also seeing checksum errors during apt-update:
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Get:3 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Get:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [172 kB]
Get:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [34.0 kB]
Err:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages
Hash Sum mismatch
- Filesize:34000 [weak]
- SHA256:8a65365b24744683c70ddf2fcda1c578f828ba926025ab6c10ce59fa47cadca3
- SHA1:41af19d859e32695d8339a543b5f59c38b750609 [weak]
- MD5Sum:5812a1a530294fc16f102f8ab77df52e [weak]
- SHA256:8192ac0db16c34e710338c6f52018aae9879efbdef3bca00ea3664473dc4bb10
- SHA1:46a2f02882a72a7166ced6556975bdc8831c5983 [weak]
- MD5Sum:2ce2d1cca66fd178cad12672b6220862 [weak]
- Filesize:33996 [weak]
Last modification reported: Thu, 09 Aug 2018 12:16:44 +0000
Release file created at: Thu, 16 Aug 2018 13:06:13 +0000
Get:6 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.9 kB]
Fetched 12.0 MB in 40s (293 kB/s)
E: Failed to fetch http://archive.raspberrypi.org/debian/d ... ackages.gz Hash Sum mismatch
I'm seeing this on two separate devices, on old Pi Model B, and a Pi Zero W. Both have ample SD card space. Interestingly, I'd previously done an update on all three of my Pi 3Bs without any problems. While the update is in process, it briefly flashes something about the package/index gpgv - relevant?
Posted: Thu Aug 16, 2018 4:16 pm
by awrc
Problem seems to have cleared up for me.
