Richard001
Switch from Pi2 to Pi3 without a new install of Raspbian
Fri Jul 20, 2018 11:06 am
i've installed raspbian stretch on my pi2 and made a lot of settings so i'm glad that all is running well. now i've purchased a raspi pi3b+ and tried booting from the existing image - that failed. this is a known error, as a user told me in the german raspberry pi forum. i updated the raspbian using dist-upgrade and tried it again because i thought a kernel update is enough to have the right driver installed. but booting also failed.
is there any way to get my existing image booting on the pi3 or is a new installation the only way?
richard
topguy
Re: Switch from Pi2 to Pi3 without a new install of Raspbian
Fri Jul 20, 2018 12:06 pm
If you do a
dpkg -l | grep raspberrypi-
and post the result here, I'm thinking someone can verify if your kernel and firmware is too old or if there is another problem.
You could also post the contents of "/boot/cmdline.txt"
klricks
Fri Jul 20, 2018 12:24 pm
If your SD card has the NOOBs installer on it, then NOOBs must be updated as well.
viewtopic.php?t=212452
Probably easier to start fresh however.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
Richard001
Fri Jul 20, 2018 12:58 pm
yes, a fresh install is possible, but it was hard work to get all the programs to work. i had some problem with some of them on stretch.
ii  libraspberrypi-bin                     1.20180703-1                      armhf        Miscellaneous Raspberry Pi utilities
ii  libraspberrypi-dev                     1.20180703-1                      armhf        EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV (headers)
ii  libraspberrypi-doc                     1.20180703-1                      armhf        EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV (headers)
ii  raspberrypi-artwork                    20150921                          all          Copy of the Raspberry Pi logo
ii  raspberrypi-bootloader                 1.20180703-1                      armhf        Raspberry Pi bootloader
ii  raspberrypi-kernel                     1.20180703-1                      armhf        Raspberry Pi bootloader
ii  raspberrypi-net-mods                   1.2.7                             all          Network configuration for the Raspberry Pi UI
ii  raspberrypi-sys-mods                   20180328+1                        armhf        System tweaks for the Raspberry Pi
ii  raspberrypi-ui-mods                    1.20180706                        all          Config to customise the LXDE UI for the Raspberry Pi
cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait splash plymouth.ignore-serial-consoles quiet
LTolledo
Fri Jul 20, 2018 1:21 pm
this is the result of mine in a RPi3B+
$ dpkg -l | grep raspberrypi-
ii  raspberrypi-ui-mods                                              1.20180530                                all          Config to customise the LXDE UI for the Raspberry Pi
the raspberry-ui-mods version number is different from yours
my RPi3B+'s USB Flash memory native boot Raspbian Stretch system was exported out from an RPi3B microSD NOOBs-Jessie-installed-upgraded-to-stretch system. Last update and upgrade was done last 2018-07-15.
Like you, I wanted to preserve my settings on the packages that was installed before, as a fresh install will be quite a chore....
Some people be like:
Richard001
Fri Jul 20, 2018 2:39 pm
i tried to update noobs (my system is a dual boot system with 2 raspbian) as described here viewtopic.php?t=212452. now the boot process starts but it hangs. this is the error:
you are in emerrgency mode. after logging in, type journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or ^D to
try again to boot into default mode.
cannot open access to console, the root account is locked
press enter to continue.
the pi starts without problems on pi2. maybe it was a problem to reboot on the pi2 after updating noobs?
Richard001
Fri Jul 20, 2018 2:51 pm
i fixed the problem. i disabled this line in my fstab and now raspbian starts.
#UUID=e3913952-81a1-420a-83ab-7ae62809f431      /media/usb      ext4    defaults        0       0
but whats wrong with that?
there is also this line
UUID=d5741696-f814-46fd-8842-95a8f5d66ec3      /media/pi/SETTINGS      ext4    defaults        0       0
but i never added it to the fstab.
donbrew
Mon Jul 23, 2018 10:01 pm
Probably because Raspbian with Desktop auto mounts USB drives in /media. And since you forced it to be /media/usb it could not find it.
Return to “Raspbian”
