Elliott B
systemd service won't run at startup
Wed Jul 18, 2018 8:52 am
I've created a startup service to stream a camera, and it's not loading at startup, but it does work if I start it manually After a reboot, the service is dead:
$ sudo systemctl status stream
● stream.service - Stream raspicam
   Loaded: loaded (/etc/systemd/system/stream.service; disabled; vendor preset: enabled)
   Active: inactive (dead)
If I start it manually, the command stalls and I have to hit Ctrl-C. After doing this, it says "activating" forever, but it works.
$ systemctl status stream
   Active: activating (start) since Wed 2018-07-18 01:47:53 PDT; 1min 19s ago
Cntrl PID: 423 (sh)
   CGroup: /system.slice/stream.service
           ├─423 /bin/sh -c /usr/bin/raspivid -n -ih -t 0 -rot 180 -w 1280 -h 720 -b 1000000 -fps 30 -o - | nc -lkv4
           ├─424 /usr/bin/raspivid -n -ih -t 0 -rot 180 -w 1280 -h 720 -b 1000000 -fps 30 -o -
           └─425 nc -lkv4 8080
Jul 18 01:47:53 raspberrypi systemd[1]: Starting Stream raspicam...
Jul 18 01:47:53 raspberrypi sh[423]: Listening on [0.0.0.0] (family 2, port 8080)
Here is my service:
[Unit]
Description=Stream raspicam
[Service]
Type=forking
ExecStart=/bin/sh -c "/usr/bin/raspivid -n -ih -t 0 -rot 180 -w 1280 -h 720 -b 1000000 -fps 30 -o - | nc -lkv4 8080"
Restart=on-abnormal
LimitNOFILE=65536
[Install]
WantedBy=multi-user.target
epoch1970
Re: systemd service won't run at startup
Wed Jul 18, 2018 9:06 am
With an absolute path to "nc"?
Wed Jul 18, 2018 9:46 am
Try creating these three services
/etc/systemd/system/raspivid.service
[Unit]
Description=raspivid process
Requires=netcat.socket
After=netcat.socket
Wants=netcat.service
[Service]
TimeoutStartSec=infinity
Sockets=netcat.socket
StandardOutput=fd:netcat.socket
StandardError=journal
ExecStart=/usr/bin/raspivid -n -ih -t 0 -rot 180 -w 1280 -h 720 -b 1000000 -fps 30 -o -
Restart=always
RestartSec=5s
[Install]
/etc/systemd/system/netcat.service
[Unit]
Description=netcat process
After=netcat.socket
[Service]
StandardInput=fd:netcat.socket
ExecStart=/bin/nc -lkv4 8080
Restart=always
RestartSec=5s
[Install]
/etc/systemd/system/netcat.socket
[Unit]
Description=netcat.service reads from this
[Socket]
ListenFIFO=/run/netcat.sock
SocketMode=0600
RemoveOnStop=false
[Install]
Note: I've not tested that stuff.
Elliott B
Thu Jul 19, 2018 6:50 am
Thanks Dougie! That works. I'll have to read up on all those options. I kind of feel weird about using three services instead of one, do you think this is a recommended practice?
I realized I just made a mistake of not enabling my service the first time. So if I do it in one forking service as I wrote before, it actually does work, the only "problem" is that systemctl status stream.service always shows "activating" forever.
Thu Jul 19, 2018 7:43 am
It's the systemd way of doing plumbing. You're sending the standard output (stdout) from the raspivid process through the socket process into the standard input (stdin) of the netcat process. It's ugly but you can stop and restart the three processes without breaking things.
Return to “Raspbian”
