ise7
Desktop Shortcut for Pi script; Nothing is working for me
Mon Jul 16, 2018 8:53 am
Seems like this would be ez but i just can't seem to figure it out. Used google and search and none of the solutions seem to be working for me.
I have a python script that I want to create a desktop short cut for.
The script is located on the USB stick @ /media/pi/SMT_DATA/SMT2.py
I want to use my python 3.6 install and berryconda located in /home/pi/berryconda3
In my script I have #!/usr/bin/env python at the top
I also used chmod +x SMT2.py
I created a desktop entry on desktop
This one gives me a invalid desktop entry
[Desktop Entry]
Type=Application
Name=SMT Program
Exec=/media/pi/SMT_DATA/SMT2.py
Icon=/media/pi/SMT_DATA/files/SMT.ico
StartupNotify=true
This one I copied from another post just spins and nothing happens?
[Desktop Entry]
Type=Application
Name=SMT Program
Exec=lxterminal /media/pi/SMT_DATA/SMT2.py
StartupNotify=true
What am i doing wrong?? Why is it so hard to do something so simple????? Linux is making me tear my hair out
topguy
Re: Desktop Shortcut for Pi script; Nothing is working for me
Mon Jul 16, 2018 12:05 pm
If you run this in a terminal opened on the desktop.
/usr/bin/env python --version
Do you get correct Python version ?
klricks
Mon Jul 16, 2018 12:51 pm
In your first desktop entry try:
Exec=python /media/pi/SMT_DATA/SMT2.py
In the second desktop entry try:
Exec=lxterminal -e python /media/pi/SMT_DATA/SMT2.py
Note if Python 3 then use python3 above.
Also note..... To test, run your script from the command line. In general if it does not work from the CL then it is not going to work as a Exec
Edit:
just noticed that you installed python 3.6 so use the complete path
Exec=lxterminal -e /path/python /media/pi/SMT_DATA/SMT2.py
Again whatever works from CL.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
ise7
Tue Jul 17, 2018 10:09 am
Hey guys thanks for the help I did get it working with the complete path! But I just had some questions regarding what I'm actually doing
This was the working code finally, what does the -e do? Also what is the difference between Exec=lxterminal and leaving it out?
Exec=lxterminal -e /home/pi/berryconda3/bin/python3.6 /media/pi/SMT_DATA/SMT2.py[code]
When I run the code below in terminal i get Python 3.6.1 does this mean It's part of my env?
When the below code doesn't work is it because my env is misconfigured or should the first line in my script not be #!/usr/bin/env python?
Also any advice on how to get the script to run automatically when the pi is turned on?
Again thanks for all the help guys! I spent all weekend trying to figure this out.
topguy
Tue Jul 17, 2018 11:49 am
"lxterminal" is the name of the terminal program.
"-e" tells lxterminal to run the following command instead of just giving you a shell.
It means the first "python" found when using the $PATH variable in your environment variable is Python 3.6.1
Run these in a terminal.
echo $PATH
which python
ls -l $(which python)
I have a standard setup on my Pi so it looks like this:
[email protected]:~$ which python
/usr/bin/python
[email protected]:~$ which python2
/usr/bin/python2
[email protected]:~$ which python3
/usr/bin/python3
[email protected]:~$ ls -l $(which python)
lrwxrwxrwx 1 root root 9 Mar 28  2015 /usr/bin/python -> python2.7
[email protected]:~$ ls -l $(which python2)
lrwxrwxrwx 1 root root 9 Mar 28  2015 /usr/bin/python2 -> python2.7
[email protected]:~$ ls -l $(which python3)
lrwxrwxrwx 1 root root 9 Dec  6  2014 /usr/bin/python3 -> python3.4
klricks
Tue Jul 17, 2018 12:50 pm
Edit autostart and add your command to the end of what's there:
nano /home/pi/.config/lxsession/LXDE-pi/autostart
@lxterminal -e /home/pi/berryconda3/bin/python3.6 /media/pi/SMT_DATA/SMT2.py
To test you can logout and back in... faster than rebooting.
ise7
Wed Jul 18, 2018 10:54 am
Hey thanks again for the help.
Adding those lines to autostart allow my script to load automatically when i log off and login but not when opening the device fresh.
Is there something I'm missing to allow it to autoload with the power plugged in?
klricks
Wed Jul 18, 2018 12:41 pm
Make a bash script and add a sleep command. Then start the script from autostart:
nano my_script
#!/bin/bash
sleep 5   # adjust time as needed
autostart:
@bash /home/pi/my_script
ise7
Wed Jul 18, 2018 11:17 pm
it works great! Thanks so much for the help
Return to “Raspbian”
