asb
New stable firmware update
Tue Oct 30, 2012 12:13 pm
Hi all. I updated the stable apt source with repackaged firmware which provides support for arbitrary memory splits on the new 512M boards. Sorry for the delay there. You should be able to upgrade with:
sudo apt-get update && sudo apt-get install raspi-config libraspberrypi*
We no longer need a whole bunch of start.elf files, and instead the amount of GPU memory can be specified in /boot/config.txt. I have updated raspi-config to support this, which you may find more convenient. Unlike previous (and future) updates, this one will require you to re-set your preferred memory split if it was something other than the default.
Upon upgrade, it will default to 64MiB GPU and the rest to ARM. If you wish to change that, just run `sudo raspi-config` and make the appropriate change.
Any issues, let me know. There's also a 2012-10-28-wheezy-raspbian.zip up on the downloads page now.
RaTTuS
Re: New stable firmware update
Tue Oct 30, 2012 12:17 pm
+1 updating one image now....
great work
Covfefe
shuckle
Tue Oct 30, 2012 1:32 pm
Seems to work.
Are these the correct new versions:
$ uname -a
Linux raspberrypi3 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
$ sudo vcgencmd version
Oct 25 2012 16:37:21
Copyright (c) 2012 Broadcom
version 346337 (release)
SirLagz
Tue Oct 30, 2012 1:41 pm
Awesome. Great time for me to be getting back into the Pi then :D
asb
Tue Oct 30, 2012 1:46 pm
shuckle wrote:Seems to work.
$ uname -a
Yes, the firmware is the version as of https://github.com/raspberrypi/firmware ... 8c75308773 as the changes introduced in https://github.com/raspberrypi/firmware ... a6098c46d5 have not been widely tested enough yet.
Boezelman
Tue Oct 30, 2012 1:59 pm
Nice work!
I keep my Pi up-to-date, so nothing new for me :D
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
ski522
Tue Oct 30, 2012 2:21 pm
Boezelman wrote:Nice work!
Yeah, but you have 3 not upgraded ;)!
RadioactiveMouse
Tue Oct 30, 2012 2:40 pm
I ran the update fine although now I'm having problems booting.
I reconfigured the RAM split and now booting fails.
I have had a look at the config file on the SD card and the top half looks like total junk followed by human readable settings below it.
I'd rather not have to recompile Go, Riak and Redis so if anyone has any ideas that would be very helpful :)
RadioactiveMouse
Tue Oct 30, 2012 4:06 pm
RadioactiveMouse wrote:I ran the update fine although now I'm having problems booting.
Tried removing the overclocking information from the config.txt, also with and without the gunk above it in the config text file I mentioned earlier.
I should also say that I've tried the kernel recovery image and also used a standard bootcode.bin from the wiki to no avail :/
I've tried my other SD card and it seems to work fine so it's not the polyfuse either.
Pretty much sure it's totally hosed now.... Anyone?
laurent
Tue Oct 30, 2012 4:08 pm
Your file seems to be corrupted.
How did you reboot after you had modified the configuration file ?
A "sync" command before any reset/power off makes sure any modification on file system is done.
RadioactiveMouse
Tue Oct 30, 2012 4:10 pm
I called "sudo reboot" after exiting raspi-config
asb
Tue Oct 30, 2012 4:13 pm
You do seem to be running in to corruption on your FAT partition. A while back there were some issues with occasional FS corruption on the FAT partition. How long has this image been in use - is it one you've updated multiple times? It may well be there was some existing corruption which caused the file updates to cause havoc.
RadioactiveMouse
Tue Oct 30, 2012 4:19 pm
asb wrote:You do seem to be running in to corruption on your FAT partition. A while back there were some issues with occasional FS corruption on the FAT partition. How long has this image been in use - is it one you've updated multiple times? It may well be there was some existing corruption which caused the file updates to cause havoc.
I'd imagine it's been around a little over a month as I have had to recompile Go and Riak since then. I have run updates when I've remembered but this is the first that has caused any issues. I suppose there is no way to recover such a corruption?
asb
Tue Oct 30, 2012 4:32 pm
I'd recreate the FAT partition. Do you have a Linux machine? If so I'd first make sure the FAT partition is unmounted, then:
sudo mkdosfs -S 512 -s 16 -v /dev/SD_CARD_PART1 # e.g. /dev/sdb1 for me
Then you can mount that partition and copy fresh files in to it (for convenience, you can untar the contents of http://asbradbury.org/tmp/raspi/2012_10_30_boot.tar.gz).
magic_man185
Tue Oct 30, 2012 5:35 pm
So is there any difference between running the commands given by asb, and running rpi-update? This method seems to be easier for someone who doesn't have rpi-update already installed. I think it is, from what I know I think rpi-update lets you update your firmware before it is stable, right? So since this was updated to stable there is no need to do rpi-update?
Thanks.
asb
Tue Oct 30, 2012 5:40 pm
magic_man185 wrote:So is there any difference between running the commands given by asb, and running rpi-update? This method seems to be easier for someone who doesn't have rpi-update already installed. I think it is, from what I know I think rpi-update lets you update your firmware before it is stable, right? So since this was updated to stable there is no need to do rpi-update?
Thanks.
Running rpi-update will give you a slightly newer and less tested version of the firmware. Use whichever method you're comfortable with, but be prepared you may sometimes experience breakage when running off the latest bleeding edge firmware.
magic_man185
Tue Oct 30, 2012 5:43 pm
asb wrote: Running rpi-update will give you a slightly newer and less tested version of the firmware. Use whichever method you're comfortable with, but be prepared you may sometimes experience breakage when running off the latest bleeding edge firmware.
Thank you. What would be the equivalent to installing the new image provided by the foundation? I don't need bleeding edge, I essentially want to be right where I would be with the new image, without having to reinstall everything.
Thanks again.
asb
Tue Oct 30, 2012 5:45 pm
magic_man185 wrote: Thank you. What would be the equivalent to installing the new image provided by the foundation? I don't need bleeding edge, I essentially want to be right where I would be with the new image, without having to reinstall everything.
Thanks again.
Following the instructions in the first post in the thread will leave you with something roughly equivalent to my regenerated 2012-10-28-wheezy-raspbian.zip
sjfaustino
Tue Oct 30, 2012 6:48 pm
asb wrote:Hi all. I updated the stable apt source with repackaged firmware which provides support for arbitrary memory splits on the new 512M boards. Sorry for the delay there. You should be able to upgrade with:
I just tried it and got:
[email protected] ~ $ sudo apt-get update && sudo apt-get install raspi-config libraspberrypi*
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://mirrordirector.raspbian.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Get:1 http://mirrordirector.raspbian.org wheezy/main armhf Packages [9,463 kB]
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 1 B in 1min 15s (0 B/s)
W: Failed to fetch gzip:/var/lib/apt/lists/partial/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages  Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
Any idea why?
asb
Tue Oct 30, 2012 6:50 pm
I'm going to blame it on a transient issue with one of the mirrors in the Raspbian mirror system.
RadioactiveMouse
Tue Oct 30, 2012 7:40 pm
asb wrote:I'd recreate the FAT partition. Do you have a Linux machine? If so I'd first make sure the FAT partition is unmounted, then:
Thanks.
I managed to get it sorted eventually by replacing all the data I could see when looking at the SD card(obviously backing up as well). I unzipped your data and realised I could just replace it like for like.
After I did that it was fine.
Thanks again :)
k6rtm
Tue Oct 30, 2012 8:32 pm
trying to update with
sudo apt-get update
gives me (after a while)
Reading package lists... Error!
E: Problem parsing dependency Depends
E: Error occurred while processing freediams (NewVersion2)
E: Problem with MergeList /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages
E: The package lists or status file could not be parsed or opened.
I'm running
Linux raspberrypi 3.2.27+ #160 PREEMPT Mon Sep 17 23:18:42 BST 2012 armv6l
Any ideas, or just try again later?
cheers--
bob K6RTM
birdman
Wed Oct 31, 2012 1:05 am
I too ended up with a system that would not reboot after doing:
aptitude update
aptitude safe-upgrade
aptitude clean
I switched back to the previous /boot files, which worked.
No idea I might have to update config.txt (as the update made no mention of it, and the file hadn't been changed).
I did report it as a bug on the Raspbian site.
shuckle
Wed Oct 31, 2012 10:29 am
I got also problems while upgrading my second RPi (also 256 version):
1) the sudo apt-get upgrade hang with:
Setting up raspberrypi-bootloader (1.20121025-1) ...
Memory split is now set in /boot/config.txt.
You may want to use raspi-config to set it
Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Removing 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Removing 'diversion of /boot/kernel_cutdown.img to /usr/share/rpikernelhack/kernel_cutdown.img by rpikernelhack'
Removing 'diversion of /boot/kernel_emergency.img to /usr/share/rpikernelhack/kernel_emergency.img by rpikernelhack'
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack
After that I waited half an hour without progress and tried also to ssh into it, but no answer. Then I rebooted and it became up fine.
2) Now it says:
$ LANG=C sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
The following packages have been kept back:
libmikmod2 lxsession openssh-client openssh-server
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
What does that mean? Kept back??
3) in the dmesg there are now strange /(but harmless) messages:
[ 25.046698] bcm2835 ALSA card created!
[ 25.059906] bcm2835 ALSA chip created!
[ 25.065977] bcm2835 ALSA chip created!
[ 25.084021] bcm2835 ALSA chip created!
[ 25.096201] bcm2835 ALSA chip created!
[ 25.108086] bcm2835 ALSA chip created!
[ 25.113755] bcm2835 ALSA chip created!
[ 25.132759] bcm2835 ALSA chip created!
[ 29.140870] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 29.151746] mmc0: DMA IRQ 6 ignored - results were reset
[ 29.159940] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 29.170922] mmc0: DMA IRQ 6 ignored - results were reset
[ 33.018981] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 33.157260] bcm2835-cpufreq: switching to governor ondemand
4) after sudo reboot, it does not wake boot anymore.
shuckle
Wed Oct 31, 2012 11:04 am
I recovered the system by copying files:
kernel_cutdown.img
kernel.img
bootcode.bin
from a workgin system. All of those files were missing. Not sure if they all are needed, but now the system works again.
Return to “Raspbian”
