Is it only possible to use the new version with increased RAM only after a rpi-update? I'm wondering how to manage an update process for 256 and 512 RPi's. From what I saw the only possibility is to run rpi-update to perform a self update, delete some files, because otherwise rpi-update thinks the FW is already up to date, run rpi-update once more to proceed the update, edit config.txt for the memory split settings and then reboot!
Is this the right and only way?
