Gadgetguy
Is Raspbian’s Chromium version too old to cut the mustard?
Thu May 10, 2018 10:20 pm
Today I did an update/upgrade on my raspbian stretch system for the first time in about 10 days which included an upgrade to rpi-chromium mods. On trying to access via chromium browser, a reputable news(paper) site: http://nationalpost.com/ that I normally frequent without any problems, I am greeted by a popup requesting that I turn off adblocking. If I don’t I can’t read the content. I have disabled ublock origin and I have no other adblock extensions. In Chromium’s content settings I have allowed the site in the flash and popup settings. I can access the site in Vivaldi snapshot which uses Chromium 65 as its engine and likewise with Chrome in Windows OS. I can also access site with no problems in Kweb and Epiphany. I can’t see any tweaks that would circumvent this issue in chromium flags. But I do see that starting with Chromium 64 there is a content setting for ads:
https://www.howtogeek.com/342986/how-to ... all-sites/
Any suggestions to remedy this problem in Chromium. I hasten to add I am very happy with and grateful for the hw accelerated Chromium on the Pi and I can imagine it is a lot of work to compile a newer version but are age related deficiencies starting to manifest themselves?
ShiftPlusOne
Re: Is Raspbian’s Chromium version too old to cut the mustard?
Thu May 10, 2018 10:30 pm
Working on a newer version and a way to speed up future releases it as we speak. In the meantime, you could give vivaldi a go.
Gadgetguy
Thu May 10, 2018 10:46 pm
Great and thanks!. Yes I like Vivaldi as well, it's nice to have variety and choice. It's interface and tweaks to Chromium have certain advantages and I daresay disadvantages. I do note that it doesn't decode video in browser quite as efficiently as chromium. 1080p in Vivaldi stutters. buffers and loses audio sync but 720p performance is acceptable.
ShiftPlusOne
Wed May 16, 2018 9:40 pm
A newer version should've hit the repo earlier today. Any difference?
ShiftPlusOne
Wed May 16, 2018 9:46 pm
Just checked that site on my desktop in firefox. i've disabled AdGuard and it still complains.
Firefox also gives information about that site not being secure. I think the problem is most likely on their end.
Gadgetguy
Thu May 17, 2018 12:12 am
Thanks for the updated Chromium! Strangely I can access that problem site via Chromium both old and new versions, if I use a user agent switcher extension( very useful tools by the way). I can also still access it via Raspbian Vivaldi and Windows OS’s Chrome browser even without a change in user agent. One strange thing about the updated Chromium in Raspbian is that the content settings have no ads configuration option whereas Windows Chrome has had an ads setting since version 64.
cjan
Thu May 17, 2018 1:00 am
it had ads option.
Gadgetguy
Thu May 17, 2018 1:12 am
it had ads option.
In Windows Chrome there is an ads option in settings/advanced/content right below plugins. I do not see any ads option in recent versions of Raspbian;s Chromium which seems curious to me.
Gadgetguy
Thu May 17, 2018 4:38 am
I am rather embarrassed to admit the reason I was receiving the pop-up on the aforementioned problem website telling me to disable ad-blocking was because while I had not enabled ad-blocking specifically in Chromium I had enabled an ad-blocker for all browsers by replacing my Raspbian default hosts file: /etc/hosts with the MVPS hosts file, found at:
http://winhelp2002.mvps.org/hosts.htm
Moreover I was using an outdated mvps hosts file. When I either restore Raspbian’s default host file or use the most recent MVPS hosts file and reboot my raspberry pi I no longer receive the popup. Untill I recently experienced this popup I had not experienced any signifigant problems or drawback from using the MVPS hosts replacement. It is strange however that the only browser that precipitated the popup was Chromium. All the other browsers loaded the site without problem. Subjectively I have noticed much better browser performance using the mvps hosts file when browsing ad infested pages using a relatively weak cpu such as the raspberry pi
If you are not familiar with this Mvps blocker and are interested in trying it you can find more information at:
HOW TO: improve browser experience:
viewtopic.php?t=174034
HOWTO setup adblock (for midori and all browsers):
viewtopic.php?t=37331
lgalex
Fri Oct 05, 2018 3:20 am
Is there anything new about this way to "speed up future releases"? Chromium 65 is at least 6 months old now and there has been between 10 and 20 updates (containing multiple security fixes) since then.
ShiftPlusOne
Fri Oct 05, 2018 8:16 am
There has been a release since that post was made, which included the changes I mentioned. I don't have control over when we get a new patch, but I did do what I could to help get a release out quickly when I do.
lgalex
Fri Oct 05, 2018 2:12 pm
I know there was a release since that post... the 65 being 6 months old was referring to the latest available chromium from raspbian. It can be problematic, especially with the newer PIs that I think more and more people use as general purpose computers to browse the web and do all sorts of stuff. But since you said you were working on a way to speed up future releases, I simply wondered if there was any progress or if the idea was abandoned for some reason.
ShiftPlusOne
Fri Oct 05, 2018 2:51 pm
Yes, I've done that so that when I get something to release, I can do so quickly. In the past there would've been a week or two delay, which has been reduced to a day or two. However, when this happens isn't up to me.
The dev who did video acceleration work on chromium is currently working on something else, which is why there hasn't been another release yet.
lgalex
Sat Oct 06, 2018 4:33 pm
Ok I understand. I wish I was able to help...
I hope it gets faster in the future, or that another browser like Firefox gets more frequent updates in the meantime (yes, I know about Vivaldi ;) )
Thanks again
lgalex
Mon Oct 15, 2018 4:45 am
ShiftPlusOne wrote: The dev who did video acceleration work on chromium is currently working on something else, which is why there hasn't been another release yet.
Wouldn't it be, especially for a learning platform like the RaspberryPi, better to have an updated secure browser without modern video acceleration stuff if it's too hard to do frequent updates? I would rather have a more simple but safe and updated browser by default and have the option to install something else if I want to do more.
It's not like chromium can do a lot on the Pi anyways... even on a Pi3b+, most hd video stuff barely works and interactive things like google maps are simply impossible to use.
yan
Mon Oct 15, 2018 7:27 am
I have Pi3b and i can watch 720p videos from youtube and other sources without a problem.Do you have h264ify addon installed in chromium?
Also, you can use omxplayer to watch any kind of video with full hardware acceleration.
For this you need to install omxplayer gui, check here: [url][https://www.raspberrypi.org/forums/view ... =40860[url]
Or you can do it manually:
First install youtube-dl.To learn about youtube-dl check here: https://rg3.github.io/youtube-dl/
sudo pip install --upgrade youtube-dl
Then run the follow command to play the video url
omxplayer `youtube-dl -g -f best ADD_VIDEO_URL`
For google maps better prefer the lite version.
Google maps Lite version: https://google.com/maps/lite
ShiftPlusOne
Mon Oct 15, 2018 8:20 am
You could make that argument, yes. I don't think it would convince enough people.
lgalex
Mon Oct 15, 2018 2:04 pm
Yeah... I guess so, otherwise it would probably already be like that :roll:
jdonald
Wed Jan 16, 2019 6:16 am
I noticed Chromium 71 works fine on the Ubuntu 18.04 images, so lately I've been running that binary on Raspbian. I'm sharing the modified binaries and packaging script here: https://github.com/jdonald/chromium-rpi-update
As I'm not building from source this should be easier to keep up-to-date.
The main use I've had for Chromium 71 on the Pi is WebGL functionality, which seems to fall short in version 65.
Gavinmc42
Wed Jan 16, 2019 6:42 am
What's 71 like in Raspbian?
We are using 72 in Gentoo64 and the WebGL Aquarium now runs - slowly ;)
How to speed up WebGL?
Is it using OpenGLES hardware acceleration or software?
I'm dancing on Rainbows.
Gavinmc42
Wed Jan 16, 2019 7:20 am
cjan
Thu Jan 17, 2019 1:40 am
do you try wayland support?
https://www.phoronix.com/scan.php?page= ... provements
Return to “Raspbian”
