rin67630
Where can i find a libusb-dev?
Tue May 08, 2018 4:20 pm
Upon attempting to install libusb-dev on a fresh upgraded raspbian stretch, I got this message:
$ sudo apt-get install libusb-devReading package lists... Done
Building dependency tree
Package libusb-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libusb-0.1-4
I have now made several attempts to install libusb[any version number]-dev but was never successful.
Compiling always breaks with
dl161s.c:11:17: fatal error: usb.h: No such file or directory
 #include <usb.h>
compilation terminated.
Has someone got a clue?
topguy
Re: Where can i find a libusb-dev?
Tue May 08, 2018 6:24 pm
Do you plan to use libusb0.1.4 or libusb1.0 or doesnt it matter ?
If you install the developer package for 0.1.4 you should find <usb.h>
https://packages.debian.org/stretch/arm ... v/filelist
But if you installed the other package for version 1.0 then you have to use <libusb-1.0/libusb.h>
rin67630
Tue May 08, 2018 7:41 pm
Tank you for your reply. I am currently tying to follow installation instructions, so im not aware of the dependencies.
I can't install libusb-1.0-0-dev either, same messages...
Is my /etc/Apt/sources.list defective?
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free$
it is a bit strange, I can't install synaptic neither...
$ sudo apt-get install synaptic
Package synaptic is not available, but is referred to by another package.
E: Package 'synaptic' has no installation candidate
I must have got a bug elsewhere...
Paeryn
Tue May 08, 2018 8:35 pm
Did you remember to do a
sudo apt-get update
to update apt's database of packages before trying to install?
She who travels light — forgot something.
rin67630
Tue May 08, 2018 8:38 pm
sudo apt-get update
Yes, I forgot to mention:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get distr-upgrade
rpdom
Tue May 08, 2018 8:46 pm
sudo apt-get update
sudo apt-get update
Try
sudo apt-get update
Paeryn
Tue May 08, 2018 9:46 pm
I wonder if the package list is corrupt? What do you get when you do :-
[email protected]:~/share $ ls -lh /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_main_binary-armhf_Packages
-rw-r--r-- 1 root root 59M May  6 17:34 /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_main_binary-armhf_Packages
If the size is showing as less than 59M (or thereabouts) then the list could be corrupt. apt-get update downloads these lists so it should be safe to delete (or move it to another directory just in case) it and redo the update to get a fresh copy.
rin67630
Re: Where can i find a libusb-dev? [solved after reinstall]
Wed May 09, 2018 2:47 am
I just lost patience with myself and reinstalled from noobs.
It works now.
Sorry for the disturbance.
rin67630
Re: Where can i find a libusb-dev? Not really solved.
Thu May 10, 2018 2:56 pm
Maybe I have leveraged a bug.
After a fresh reinstall from noobs, I could run
sudo apt-get install libusb-devlibusb-de
But after I ran my usual cleanup of default packages, that are useless to me:
sudo apt-get purge wolfram-engine
sudo apt-get purge libreoffice
sudo apt-get purge scratch
sudo apt-get purge sonic-pi
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get autoremove
I got the same error again:
  libusb-0.1-4
The usual update/upgrade procedure does not help:
sudo apt-get update
The repos from update seem ok, isn't it?
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Get:4 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [30.8 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.8 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages [95.2 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages [1,360 B]
It seems that apt-get runs weird.
I can't reinstall what I just purged:
sudo apt-get install wolfram-engine now throws a bunch of errors:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 wolfram-engine : Depends: coinor-libipopt1v5 but it is not installable
                  Depends: libraw15 but it is not installable
                  Depends: libgmime-2.6-0 but it is not installable
                  Depends: libexiv2-14 but it is not installable
E: Unable to correct problems, you have held broken packages.
Has anyone got a clue?
yepecece
Sun Jun 17, 2018 7:46 am
I am having the exact same problem.
Trying to install "libusb-dev" and get the same error and also problems when reinstalling Wolfram.
Did you find a solution?
Return to “Raspbian”
