devenh
Setting default USB (/dev/ttyACM0) baud rates
Thu May 03, 2018 3:25 am
I am using a USB GPS (u-blox chipset, /dev/ttyACM0) and at boot or when the device is plugged in, the baud rate is 9600. How can I configure my system so that the baud rate is 115200 or higher at startup or when it is plugged in? (I know the stty -F 115200 /dev/ttyACM0 will change the baud rate, but I want 115200 to be the default)
More generally, does the baud rate for USB devices behave the same way as for UART devices? The reason I ask is that the u-blox GPS allows for the setting of baud rates for the UART interface, but not for USB interface. This implies that the USB interface handles baud rates differently. than UART. Is this correct?
topguy
Re: Setting default USB (/dev/ttyACM0) baud rates
Thu May 03, 2018 1:04 pm
If the GPS chip has a direct USB interface ( and not just an UART with a serial2usb chip attached ), then there is no actual serial communication going on anywhere and baudrate is irrelevant. The USB has a set transferrate and will always transfer data at that speed.
Thu May 03, 2018 8:25 pm
Most GPS receivers work at 4800 8N1 (ancient old ones) or 9600 8N1 and won't drive the serial interface at any higher baud rate (because it doesn't give you any benefits when it's about publishing about five or six NMEA sentences (less than 400 bytes) each second).
Just install gpsd and use that as a simple interface to your u-blox GPS receiver.
This is a doctor free zone.
devenh
Thu May 03, 2018 9:41 pm
I'm running a 10hz update rate, so I am pushing more data through the pipe. This is why I'm always checking throughput as I don't want to overload the pipe.
Return to “Raspbian”
