prsolucoes
Jessie Lite + unofficial Touchscreen
Sat Apr 28, 2018 11:14 am
I have a problem.
I bought this:
https://www.aliexpress.com/item/New-Ras ... 0.0.sausBW
Im using Raspberry Pi 3 and it is showing the screen, but dont respond to touch events.
My current config. I tried other from web.
max_usb_current=1
hdmi_force_hotplug=1
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_drive=1
display_rotate=0
hdmi_cvt 1024 600 60 6 0 0 0
On the company website they sad to dont use lite version:
https://www.elecrow.com/wiki/index.php? ... uch_Screen
But i need use the lite version and need install the driver or something to make it work.
Can anyone help me?
SteveSpencer
Re: Jessie Lite + unofficial Touchscreen
Mon Apr 30, 2018 1:17 pm
Firstly, you should upgrade to stretch, rather than Jessie.
That said, the following is, I believe, true for both versions.
The "lite" version doesn't include any GUI elements, so the $64,000 question is, what do you expect the touchscreen to actually do?
You can see if the touchscreen is actually recognized by looking through the boot messages (dmesg), and/or by using lsusb to show what devices are present. If it is present, then you will probably need additional software to work with it.
If you run the full version, with a GUI desktop, the GUI is doing all the heavy lifting required to make it work.
I have many different touchscreens, including an earlier model of this one. In many cases, they are running software I have written that talks directly to the framebuffer to display things, and code to read and interpret the touch events. Most of these are on the "lite" version.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
Return to “Raspberry Pi OS”
