drmullins
Automount stops working after 4.14.30 kernel upgrade
Sun Apr 08, 2018 2:35 pm
Automount (using autofs with winbind) stopped working afer I upgraded from 4.9.80 to 4.14.30 kernel.
The problem is repeatable - I checked with a second sd card with same kernel update.
My /etc/auto.master and /etc/auto.sambashares (listed at bottom of this page) have
permissions set correctly as 755 (though 644 also works in some cases) and 644 respectively
These automounts have been and are still working perfectly on :
- Several Raspberry Pi 2 model B, Raspberry 3 model B, and Raspberry 3 model B+
running Raspbian Jessie and Raspian Stretch with kernels 4.9.80 or earlier
- Several old 32 bit x86 PC's running Debian Jessie and Debian Stretch
Nmap still finds all servers correctly listing the open ports
Shares can still be mounted manually using pcmanfm - Go - Network
However automount is not working at all (with 4.14.30 kernel)
I have tried adding
automount: files
as a new row in /etc/nsswitch.conf (already configured for winbind see below) but this has no effect
HELP PLEASE !
My /etc/auto.master contains :
# Sample auto.master file
# This is a 'master' automounter map and it has the following format:
# mount-point [map-type[,format]:]map [options]
# For details of the format look at auto.master(5).
#/misc /etc/auto.misc
/media/mycifs /etc/auto.sambashares --timeout=7200 --ghost
# NOTE: mounts done from a hosts map will be mounted with the
# "nosuid" and "nodev" options unless the "suid" and "dev"
# options are explicitly given.
#/net -hosts
# Include /etc/auto.master.d/*.autofs
# The included files must conform to the format of this file.
+dir:/etc/auto.master.d
# Include central master map if it can be found using
# nsswitch sources.
# Note that if there are entries for /net or /misc (as
# above) in the included master map any keys that are the
# same will not be seen as the first read key seen takes
# precedence.
+auto.master
My /etc/auto.sambashares contains :
ds215j -fstype=cifs,rw,uid=${UID},guest ://DS215J/PUBLIC
qnap112 -fstype=cifs,rw,uid=${UID},guest,sec=ntlm,nounix,noserverino ://QNAP112/Public
tplink -fstype=cifs,rw,uid=${UID},guest ://192.168.1.1/"volume(sda1)"
qnap2012 -fstype=cifs,rw,uid=${UID},guest,sec=ntlm,nounix,noserverino ://QNAP2012/Public
mybooknfs -fstype=nfs,nolock MyBookWorld:/nfs/Public
raspimusic -fstype=cifs,rw,uid=${UID},guest ://raspi6/pidrivemusic
transit -fstype=cifs,rw,uid=${UID},guest ://raspi6/transit
asus2012 -fstype=cifs,rw,uid=${UID},guest ://PERSONAL-743469/HOMESHARE
my /etc/nsswitch.conf contains :
# /etc/nsswitch.conf
# Example configuration of GNU Name Service Switch functionality.
# If you have the `glibc-doc-reference' and `info' packages installed, try:
# `info libc "Name Service Switch"' for information about this file.
passwd: compat
group: compat
shadow: compat
gshadow: files
hosts: files wins mdns4_minimal [NOTFOUND=return] dns
networks: files
protocols: db files
services: db files
ethers: db files
rpc: db files
netgroup: nis
drmullins
Re: Automount stops working after 4.14.30 kernel upgrade
Sun Apr 08, 2018 4:12 pm
I had to revert to the 4.9.80 kernel
sudo rpi-update 5c80565c5c0c7f820258c792a98b56f22db2dd03
to get automount working again
- NOT A SATISFACTORY SOLUTION GOING FORWARD.
PeterO
Sun Apr 08, 2018 4:29 pm
If you think this is a kernel issue, then maybe you should file an "issue" here : https://github.com/raspberrypi/linux/issues
PeterO
drmullins
Sun Apr 08, 2018 5:17 pm
Thanks - reported on github
Return to “Raspbian”
