mrlinux2u
Missing 'hdparm' package
Thu Mar 29, 2018 10:52 am
I've updated my Raspbian Stretch (updated this morning to the very latest kernel) and I've noticed that the 'hdparm' package can no longer be installed - is there any reason why this package is no longer available as I find it a very useful program when dealing with usb drives?
Cheers
mrlinux2u
PeterO
Re: Missing 'hdparm' package
Thu Mar 29, 2018 11:47 am
[email protected]:~ $ sudo apt-get  install hdparm
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  powermgmt-base
Suggested packages:
  apmd
The following NEW packages will be installed:
  hdparm powermgmt-base
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 114 kB of archives.
After this operation, 276 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://raspbian.mirror.uk.sargasso.net/raspbian stretch/main armhf hdparm armhf 9.51+ds-1 [105 kB]
Get:2 http://raspbian.mirror.uk.sargasso.net/raspbian stretch/main armhf powermgmt-base all 1.31+nmu1 [9,240 B]
Fetched 114 kB in 0s (195 kB/s)
Selecting previously unselected package hdparm.
(Reading database ... 172502 files and directories currently installed.)
Preparing to unpack .../hdparm_9.51+ds-1_armhf.deb ...
Unpacking hdparm (9.51+ds-1) ...
Selecting previously unselected package powermgmt-base.
Preparing to unpack .../powermgmt-base_1.31+nmu1_all.deb ...
Unpacking powermgmt-base (1.31+nmu1) ...
Setting up powermgmt-base (1.31+nmu1) ...
Setting up hdparm (9.51+ds-1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Works for me. Using up to date everything :-)
PeterO
mrlinux2u
Thu Mar 29, 2018 11:58 am
Output from my Pi :
Package hdparm is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'hdparm' has no installation candidate
mrlinux2u
Thu Mar 29, 2018 12:04 pm
Problem solved - did another sudo apt-get update and lo-and-behold the 'hdparm' package is there now - really weird as I did the same this morning and it wasn't available...
Anyway thanks for your feedback...:) :D
PeterO
Thu Mar 29, 2018 12:10 pm
That was going to be my next suggestion ..... Always do an "apt-get update" before trying to install anything to avoid such problems.
PeterO
mrlinux2u
Thu Mar 29, 2018 12:19 pm
It's a bit weird since I already did a apt-update and a apt-get upgrade which updated the kernel and several other packages...
Well you live and learn :)
PeterO
Thu Mar 29, 2018 12:29 pm
Maybe you caught something while new packages were being uploaded ? Anyway normal service has been restored. 8-)
PeterO
mrlinux2u
Thu Mar 29, 2018 12:49 pm
Yes it has :D
Still loving the Raspberry Pi's....
Cheers
mrlinux2u
Thu Mar 29, 2018 8:55 pm
There was something in the recent raspberypi-sys-mods package that changed something in the sources.lists files. I don't know if that is related.
Thu Mar 29, 2018 9:04 pm
It is. Stretch has moved house to raspbian.raspberrypi.org from mirrordirector.raspbian.org.
Return to “Raspbian”
