I've done as much research as I can. All of the .so files are actually in place so it doesn't seem to be a problem where a .ini file is calling for the load but the file isn't present. From my reading, I suspect that somehow the compiled version I've ended up with for these modules is not the correct one for my version of php7 (7.0.27-0+deb9u1). My Raspbian version is 9 (stretch). The reason that iconv occurs twice is that I was experimenting with php.ini to see if it needed the full path so it's trying to load from two different calls (I've got to take that back out of there). I also note that I can't actually issue any CLI commands to php, all I get in response is "Segmentation fault" so I further suspect that the CLI version of php is either not installed or not working properly.PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/iconv.so' - /usr/lib/php/20151012/iconv.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/ftp.so' - /usr/lib/php/20151012/ftp.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/gettext.so' - /usr/lib/php/20151012/gettext.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/posix.so' - /usr/lib/php/20151012/posix.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/shmop.so' - /usr/lib/php/20151012/shmop.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/sysvmsg.so' - /usr/lib/php/20151012/sysvmsg.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/sysvsem.so' - /usr/lib/php/20151012/sysvsem.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/sysvshm.so' - /usr/lib/php/20151012/sysvshm.so: invalid ELF header in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/20151012/tokenizer.so' - /usr/lib/php/20151012/tokenizer.so: invalid ELF header in Unknown on line 0
So do I have to re-install php ? Is there any way to save this setup and just correct the bad versions of these libraries without actually re-installing php. I'm not even sure if re-installing will install these libraries. Some of them may be dependents.
Just learned from searching that posix module is now built into php7 core. Maybe that is true for more of these. The modules are not loaded from php.ini I think it gets loaded from the matching ini file in /etc/php/7.0/apache2/conf.d/ is that correct. If so I can disable that module by moving the appropriate ini file out of that directory. Is that the correct way to shut off the call to load one of these modules?
So what to do from here? Thanks for any help/suggestions.
NK
