Raspbian not fully booting (solved)
Posted: Mon Oct 22, 2012 10:51 pm
by AshP
Hi all,
I just received my first Pi the 512mb model. I downloaded 2012-09-18-wheezy-raspbian.zip file, used Win32DiskImager to dump the image to a SD card. The Pi boots up, but after 3.8 seconds goes no further just after the USB/network detection. If I press a key I get into a # shell, without requiring username/password, but if I change for example the /etc/network/interfaces file, the change is lost on a reboot.
I've tried a couple of SD cards, tried with different power (HTC Sensation, and iPhone adaptor) and different cables all with the same result (Voltage between TP1 and TP2 is around 4.85v).
I fired up Arch Linux and that is working fine, am I missing something stupid?
Thanks!
Re: Raspbian not fully booting
Posted: Tue Oct 23, 2012 12:02 pm
by AshP
I renamed /boot/kernel_emergency.img and rebooted and it seems to be booting fine.
Posted: Thu Oct 25, 2012 10:10 pm
by AshP
The issue was caused by a blob of solder, on the underside of the board, between pins 5&6 on the GPIO. It must of came out of the factory like that as is was sealed and new from CPC.
Re: Raspbian not fully booting (solved)
Posted: Thu Oct 25, 2012 11:12 pm
by redhawk
It's nice to know that every PI is properly tested before leaving the factory. :lol:
Just out of curiosity was this shipped from RS or Farnell??
Richard S.
Posted: Fri Oct 26, 2012 7:42 am
by AshP
It was from CPC Farnell Element14 and "Made in the UK"
