skim32
Creating an Image after setting up a PI
Thu Mar 08, 2018 10:18 pm
I have my golden image for my raspberry pi with various servers and applications on it. I wanted to make an image of it so I can install it on multiple SD cards. Regardless of the size of the SD card. I tried all the major USB Image tools (w32diskimager, usbimage and etc.) However I am wondering how to create and image that will stretch to any size SD card. All the apps that I could find can only do block level imaging so if you start with a 32gb card, you need another 32gb or larger card to use the image. It has to be possible because the Raspian image that I can download from this website does it just fine. For example I can install raspain and 4gb card and it will install and stretch the volume to 4gb. And I can put it on a 32 and it will stretch it as well. However any image I make can only be put on the same size card or larger. Any ideas?
klricks
Re: Creating an Image after setting up a PI
Fri Mar 09, 2018 12:38 am
Raspbian has a SD copy utility which will make an exact copy of the running SD card (same size as original).
[Menu] -> [Accessories]
You will need to attach a USB SD card reader to the RPi.
droleary
Contact: Website Skype
Fri Mar 09, 2018 4:05 pm
I'd argue that imaging is the wrong solution for what you're doing. Odds are pretty good that each machine is going to have some other settings that differ beyond just the SD card size. Consider instead creating a metapackage for Debian or using configuration management tools.
gkaiseril
Fri Mar 09, 2018 5:06 pm
Making an exact image for another PI will require some editing of the configuration files on the copy to change the Pi's unit name and IP address at the very least. If these features are not modified a conflict in the network will arise and cause no end of problem.
SD copy or piclone can make copies of the running image to a larger or smaller SD card so long as there is enough space for the image data being copied.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
epoch1970
Fri Mar 09, 2018 6:45 pm
Resize2fs can extend an ext filesystem, but it can shrink it, too.
  • Take an image of your SD,
  • Loop-mount that image,
  • Shrink your filesystems, note their sizes,
  • Create a new image file, loop-mount it, create the adequately sized partition table in it,
  • With dd stream the right amount of bytes from each partition in the master image to those on the new image.
NOTE. In your master you would need to add some "run once" script that will expand the image to the actual size of the SD at first boot: i. alter the partition table, ii. resize2fs to expand the filesystem.
Quite fiddly overall... Parted, or Gparted on a desktop should be able to take care of the filesystem+partition resizing bit on a loop-mounted image.
I think qemu-img can be used to mount, shrink, etc. image containers better than using truncate or dd. The excellent Nairobi Embedded (try their ALSA docs!) has a nice write-up on using qemu-img.
(losetup mentioned in that page is too old. Use kpartx instead if needed)
procount
Fri Mar 09, 2018 8:59 pm
Instead of a creating an image, you could create an archive of each partition.
Use tar to create the archive then compress it using gzip or xz.
To reinstate on another sd card, create and format your partitions first then expand your archives onto the appropriate partitions. This avoids having to have exactly the same sized sd cards.
skim32
Sun Mar 11, 2018 3:27 am
Thanks for everyones replies. I am not concerned about IPs and Hostnames. I don't statically assign IPs at the host. Instead I handle that one a DHCP server. Besides IP there isn't much configuration that specific to any one machine. Hostname maybe, but that isn't a big deal for me either. I like some of the ideas suggested. AKA using PiClone. Also creating a backup of each partition by archiving them. However I wish I knew how the Raspbian imgs are created by the Raspbian team. What tool do they use that their images are stretchable, just using etcher or other img tools.
Sun Mar 11, 2018 6:49 am
They don't. There is a script that runs on the first boot that expands the file system to fill the card. The script is /usr/lib/raspi-config/init_resize.sh and it is triggered by adding the following to the end of cmdline.txt
init=/usr/lib/raspi-config/init_resize.sh
When it runs it also removes that entry so that it doesn't run on subsequent boots, and then triggers a reboot.
hoserr9
Fri Sep 18, 2020 8:55 pm
Hi RPI team,
Is there an easier way to create an image off an existing PI installation so you can install on multiple SD cards for Pis? This post is from 2018 maybe 2020 it got better/easier?
Jose
bassamanator
Sat Sep 19, 2020 2:35 am
image-backup is what you're looking for: viewtopic.php?f=29&t=247568
Pi power tools is a great tool as well and it has a GUI https://github.com/Botspot/Pi-Power-Tools
| Raspberry Pi 4-8GB | 2.0GHz | over_voltage@5 |
| Raspberry Pi OS 32bit |
| https://github.com/bassamanator/raspberrypi-scripts |
rudiratlos
Tue Sep 22, 2020 9:56 am
teamtiem
Tue Sep 22, 2020 8:58 pm
In Raspbian you have under Accessoiries SD Card Copier, You can copy a SD Card to any SD-Card bigger or smaller. The program expand or shrink the root partition as needed. All the room on the copy is used. Only when the data on the original don't fit on the copy it gives a error.
Return to “Raspberry Pi OS”
