Raspian stretch does not reconnect to wifi after restart access point
Posted: Thu Mar 08, 2018 7:32 am
by tigernero
I do not understand why if I restart my access point,
Raspian stretch does not connect again remaining in No APS scanning,
I have to restart it to re-establish the connection. I did a clean installation same problem what can it be?
Re: Raspian stretch does not reconnect to wifi after restart access point
Posted: Thu Mar 08, 2018 9:35 am
by jamesh
Are you using a hidden SSID?
I've been testing in this area, and normal SSID would rescan fine, hidden ones needs a change to wpa_supplicant.conf.
I was using the latest firmware however, and a slightly modified linux driver (both to be released soon)
Posted: Thu Mar 08, 2018 12:36 pm
by tigernero
no hidden ssid, simply wifi does not hang up anymore to its wifi after a restart of the access point, I have to restart the raspberry with raspbian to get back the wifi.
I had the problem after the latest brcm firmware updates
I solved by replacing the stretch wifi drives with those of jessy
procedure:
Download brcm_Raspbian_Jessy.rar
https://www.pensierando.it/Nextcloud/in ... LBtoeHHGsW
unzip
launch the commands
sudo mv /lib/firmware/brcm /lib/firmware/brcm-stretch
sudo mv [path_from_file]/brcm /lib/firmware/brcm
sudo apt-mark hold firmware-brcm80211 #prevent it from beeing updated
#back
#sudo apt-mark unhold firmware-brcm80211
I have the latest raspbian version which with the latest updates gave me the problem that if I restart the raspbian access point it did not reconnect.
replacing the last drives with those of jessy everything is back to work.
when will the bug be fixed?
Posted: Thu Mar 08, 2018 4:07 pm
by jamesh
We believe we have a fix for the crashes when rebooting an AP or using a hidden SSID. In my testing this week, with the latest firmware and Linux driver, the Pi did reconnect to a rebooted access point, except in the hidden SSID case, which required a change in wpa_supplicant (as outlined in another thread).
Not sure when this will be released. A few days I expect - it's clearly better than before.
Posted: Thu Mar 08, 2018 5:55 pm
by DougieLawson
Couldn't be any worse. I've got a couple of RPi3s that are not at all happy with WiFi. I'm willing to do a beta test if you can stick the fixed modules on Github (Gist), Google docs or Dropbox or somewhere.
Posted: Fri Mar 09, 2018 10:15 am
by jamesh
What you can try is the standard 4.14 with the new firmware. That combination should work and be more robust. 4.9 has a missing commit on the Linux driver that is in 4.14. Would be interested to see results.
Posted: Fri Mar 09, 2018 1:50 pm
by DougieLawson
I'm already running bdb826a8db75ba36d754bd71fb64d3905d3bd026
Linux Challenger 4.14.24-v7+ #1097 SMP Mon Mar 5 16:42:05 GMT 2018 armv7l GNU/Linux
I've been on the 4.14 kernel since it was first made available with BRANCH=next.
Posted: Fri Mar 09, 2018 2:42 pm
by jamesh
Is this with the new wireless firmware that we had to roll back?
Posted: Fri Mar 09, 2018 3:07 pm
by tigernero
I'm still with jessy's drive instead of stretch and everything's going well,
but when will you release the updated wireless firmware I will find it with sudo apt update and dist-upgrade?
Linux raspberrypi 4.14.24-v7+ #1097 SMP Mon Mar 5 16:42:05 GMT 2018 armv7l
Posted: Fri Mar 09, 2018 3:19 pm
by jamesh
The release will mean that apt upgrade/update will get it.
Currently still testing.
Posted: Fri Mar 09, 2018 3:32 pm
by DougieLawson
I think I rolled it back on all of my RPi3s.
[    7.625340] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    7.633674] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[    7.633914] usbcore: registered new interface driver brcmfmac
[    7.819713] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[    7.820648] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
Posted: Fri Mar 09, 2018 3:57 pm
by jamesh
Hmm. 4.14 in my testing with the NEW firmware works fine. Reconnected after a AP reboot. Is it possible for you to try the newest firmware? Would appreciate any reports on that particular combination.
Posted: Fri Mar 09, 2018 4:11 pm
by DougieLawson
Is that the current minus one version from apt-get? What's the date on the firmware that I need to test. Or where can I download a zipfile?
This is the current firmware
[email protected]:/lib/firmware/brcm$ strings brcmfmac43430-sdio.bin | grep 2017
Aug  7 2017
2017-08-07 00:37:47
43430a1-roml/sdio-g-p2p-pool-pno-pktfilter-keepalive-aoe-mchan-tdls-proptxstatus-ampduhostreorder-lpc-sr-bcmcps Version: 7.45.41.46 (r666254 CY) CRC: 970a33e2 Date: Mon 2017-08-07 00:48:36 PDT Ucode Ver: 1043.206
This is the version I've saved away in a "brcm_bad" folder
[email protected]:/lib/firmware/brcm_bad$ strings brcmfmac43430-sdio.bin | grep 2017
Oct 23 2017
2017-10-23 03:47:14
43430a1-roml/sdio-g-pool-p2p-idsup-idauth-pno-pktfilter-wowlpf-keepalive-aoe-lpc-swdiv-srfast-fuart Version: 7.45.98.38 (r674442 CY) CRC: ffb2ee5a Date: Mon 2017-10-23 03:58:00 PDT Ucode Ver: 1043.2099 FWID 01-e58d219f
Posted: Fri Mar 09, 2018 4:49 pm
by jamesh
Here's the firmware in Drive, but I believe it is current apt get minus one
https://drive.google.com/open?id=11wv8o ... 8bxbHDGB47
Posted: Fri Mar 09, 2018 5:18 pm
by DougieLawson
That's the 7.45.98.38 version, so I'll give that a go over the weekend.
When it fails I'm getting this from wpa_supplicant
Successfully initialized wpa_supplicant
Failed to create interface p2p-dev-wlxb827ebd88739: -22 (Invalid argument)
nl80211: Failed to create a P2P Device interface p2p-dev-wlxb827ebd88739
P2P: Failed to enable P2P Device interface
nl80211: deinit ifname=wlxb827ebd88739 disabled_11b_rates=0
wlxb827ebd88739: CTRL-EVENT-TERMINATING
Posted: Fri Mar 09, 2018 5:31 pm
by tigernero
[email protected]:/lib/firmware/brcm $ strings brcmfmac43430-sdio.bin | grep 2017
Oct 23 2017
2017-10-23 03:47:14
I just tested the brcmfmac43430-sdio.bin
from the link you have put
on my raspberry pi3
restarting the access point and it worked, after restarting it kept connecting and reconnecting.
so I can say that it worked for me
Posted: Fri Mar 09, 2018 7:53 pm
by davesteele
I just tested this situation with Comitup on the latest Stretch. It reconnects to an interrupted Access Point just fine.
https://davesteele.github.io/comitup/
