FairFight
New RPI 512 MB fails on apt-get upgrade
Sat Oct 20, 2012 1:45 pm
I have just got my new Raspberry PI 512 MB and a completely new SD card and installed Raspbian (2012-09-18-wheezy-raspbian.img).
After installing the SD card I am not able to do sudo apt-get upgrade.
It comes with the following error:
dpkg: unrecoverable fatal error, aborting:
 files list file for package 'libfm-data' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
I have reinstalled the img on the SD card, however it just comes with the same error - but for different packages. Last time it was manpages.
malakai
Re: New RPI 512 MB fails on apt-get upgrade
Sat Oct 20, 2012 3:37 pm
Try
sudo apt-get update && apt-get upgrade
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
FairFight
Sat Oct 20, 2012 3:39 pm
malakai wrote:Try
Sorry, I did not mention that I am doing a apt-get update before upgrading.
plugwash
Sat Oct 20, 2012 4:55 pm
Personally my first suspision would be a bad SD card.
FairFight
Sat Oct 20, 2012 6:25 pm
plugwash wrote:Personally my first suspision would be a bad SD card.
I just tried another plain new, out of package SD card - still same error but the package it is mentioning is now lxmenu-data.
Edit:
My SD cards is class 10 and not class 4 as suggested on raspberrypi.org - does that matter?
milhouse
Sat Oct 20, 2012 6:56 pm
FairFight wrote: I just tried another plain new, out of package SD card - still same error but the package it is mentioning is now lxmenu-data.
Have you overclocked your Pi? Try running just stock frequencies - no overclock - and see if you still have the same problem.
FairFight wrote:Edit:
Class 10 should be compatible, but obviously that advice can vary by brand. I've used SanDisk and Transcend Class 10 cards without too many issues - I do have a 256MB Pi that will corrupt every SD card - Class 10 or Class 4 - if I overclock the core frequency, but two other 512MB Pi with overclocked cores have no problems using the same cards.
JollyRoger
Sat Oct 20, 2012 6:57 pm
I have several Class 10 cards from different manufacturers and they all work. It seems that other people are having similar problems - see this thread: http://www.raspberrypi.org/phpBB3/viewt ... 66&t=17923
FairFight
Sat Oct 20, 2012 9:35 pm
milhouse wrote: Have you overclocked your Pi? Try running just stock frequencies - no overclock - and see if you still have the same problem.
No it is just stock frequencies.
JollyRoger wrote:I have several Class 10 cards from different manufacturers and they all work. It seems that other people are having similar problems - see this thread: http://www.raspberrypi.org/phpBB3/viewt ... 66&t=17923
They seem to have problems with Booting.
The device boots without problems, it is only when I am trying to apt-get upgrade/install that it has problems.
Tanga
Sun Oct 21, 2012 10:01 am
Thanks for posting this. I guess I've been lucky. I have a SanDisk 16GB class 10 card and haven't run into any of these problems. Though synaptic didn't play nice, aptitude has been beautifully behaved.
PS - I too have one of the new 512 MB cards, and it's been overclocked to medium (though the high setting caused a corrupted card :( - you live you learn).
Luck?
Raspberry Pi (Raspbian) Tutorials by a fellow noob:
http://noobsquared.blogspot.com.au/
FairFight
Tue Oct 23, 2012 12:22 pm
I'm still having problems.
Is it possible that it may be a hardware problem?
Something with the PSU or the Raspberry Pi itself?
thsBavR10
Tue Oct 23, 2012 12:26 pm
maybe
sudo apt-get autoclean  && sudo apt-get autoremove
could help.
RaTTuS
Contact: Twitter YouTube
Tue Oct 23, 2012 12:30 pm
what is your power supply like ?
Covfefe
FairFight
Wed Oct 24, 2012 3:36 pm
thsBavR10 wrote:maybe
could help.
Unfortunately it did not help :/.
RaTTuS wrote:what is your power supply like ?
I am using an old Apple iPod USB power supply.
Says Output: 5V - 1A on it - guess that should be fine?
Lob0426
Wed Oct 24, 2012 11:43 pm
I had a RasPi that had similar problems. The cards worked fine in my other RasPii. But one would cause errors every time it was written too. You may be having a similar issue. You may need to return that board.
That RasPi actually flew under the radar for a while. I was using it with a USB HDD with my rootfs on it. No errors to the HDD. But any time it wrote to the SD card it corrupted it. It only really started to show the problem when I installed stuff to the rootfs on a SD card.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
FairFight
Thu Oct 25, 2012 9:36 am
For some reason I dont know, it seems to work fine after I've used win32diskimager instead of dd on Mac OSX.
Thanks for all your suggestions though!
Return to “Raspbian”
