ngtbinh
Can not bring up wifi
Thu Jan 18, 2018 4:00 am
Hi all,
I have problem with Pi 3
I use debian 8.0
After "sudo if down wlan0"
And then "sudo if up wlan0" is can not bring up wlan0 and receive error message :
"run-parts: /etc/network/if-pre-up.d/wpasupplicant exited because of uncaught signal 11
Failed to bring up wlan0."
And when i click icon network it display "No wireless interface found"
Please help me,
Thanks you
wh7qq
Re: Can not bring up wifi
Thu Jan 18, 2018 10:17 pm
I use debian 8.0
You need to clarify which distribution you are using. The Raspberry Pi does not work with straight Debian although Raspbian uses Debian as a basis.
The RPi 3 with Raspbian should automatically find the wireless interface that is built in at boot time but you will still need to configure wireless security if your network uses it...SSID and WPA2 passphrase...in a /etc/wpa_supplicant/wpa_supplicant.conf file that looks like this:
update_config=1
country=US
network={
ssid="Your SDID"
psk="Your Passphrase"
key_mgmt=WPA-PSK
with "country code" adjusted to your country if not "US".
This can be accomplished in the current Raspbian distribution using raspi-config in "Network Options".
ngtbinh
Fri Jan 19, 2018 8:52 am
Thank wh7qq
Before there, i had use wifi good
But, after i use command "ifdown wlan0"
And then i use command "ifup wlan0" to bring up wlan0
But it can't bring up, and i have recive erorr message
Return to “Raspbian”
