zurdar
[SOLVED] How to install Python module from source?
Mon Jan 08, 2018 6:57 am
Could somebody please guide me in installing Python module from source? It's about https://github.com/Diaoul/subliminal which I've installed as per instruction using "[sudo] pip install subliminal". Problem is that version 2.0.5 that is available on PyPi is outdated and there was a vast amount of development done since it's release. I'd like to install develop branch from github, but don't even know how to start...
[UPDATE]
Just got reply in another place. In case somebody might need it in the future below is a solution:
https://stackoverflow.com/questions/201 ... epo-branch
topguy
Re: [Q] How to install Python module from source?
Mon Jan 08, 2018 1:23 pm
I'm no Python expert but..
I think you just checkout the code from git and run the "setup.py" program.
sudo python setup.py install
.... maybe.
zurdar
Mon Jan 08, 2018 1:55 pm
Thanks, will try that. Should I uninstall PyPi version first or this new one will replace it?
topguy
Mon Jan 08, 2018 2:11 pm
usually safest to uninstall first, there is a lot of details around "pip" I dont understand.
zurdar
Mon Jan 08, 2018 4:36 pm
Return to “Raspberry Pi OS”
