Jpod1003
How to use retro pi on a already installed Rasbian
Tue Dec 26, 2017 4:53 am
I downloaded Rasbian through noobs, and was wondering how do i use retro pi
Re: How to use retro pi on a already installed Rasbian
Tue Dec 26, 2017 8:12 pm
Maybe the developers website ??
https://retropie.org.uk/download/#Insta ... xisting_OS
beta-tester
Wed Dec 27, 2017 12:02 am
https://retropie.org.uk/docs/Manual-Installation/
installation of retropie on top of actual raspbian-stretch is still not supported yet.
if you try, you will end up with an error.
https://github.com/RetroPie/RetroPie-Se ... /system.sh
https://github.com/RetroPie/RetroPie-Se ... 98757a4955
line 80:
error="Sorry - Raspbian/Debian Stretch (and newer) is not yet supported on the RPI"
only raspbian-jessie is currently supported.
take a second sd card and put retropie on it.
or that the one you have and wipe out the NOOBS and put retropie on it, when you don't need raspbian.
https://retropie.org.uk/docs/First-Installation/
or make a new installation of the sd card and install PINN instead of NOOBS.
https://github.com/procount/pinn
there is also RetroPie available to install side by side with Raspbian on the same sd card.
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
Return to “Raspberry Pi OS”
