Khatharr
Set VNC resolution?
Sun Dec 17, 2017 9:38 pm
So I have a headless Pi2 running Raspbian (all up to date) and I connect to it using the bundled VNC. I've set the resolution in raspi-config as low as 640x480, but when I connect via VNC it's always at 1280x900. My question is thus how can I set the VNC resolution, since setting the desktop resolution is not doing the job?
Thanks in advance for any advice. :)
Re: Set VNC resolution?
Sun Dec 17, 2017 9:43 pm
If run in Virtual Mode, then the HELP section has information:
https://www.realvnc.com/en/connect/docs ... pi-virtual
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
Khatharr
Sun Dec 17, 2017 11:06 pm
I don't think it's in virtual mode. The settings indicated are the ones for setting the desktop resolution. I've already checked them and they're as I set them.
Thank you, though.
Sun Dec 17, 2017 11:45 pm
Thank you, though.
Run in Virtual Mode and set the desired resolution as per instructions for ""Specifying a screen resolution for a virtual desktop""
Khatharr
Mon Dec 18, 2017 12:09 am
If I'm understanding correctly, you're saying that I should disable the bundled VNC server, install a different one, and change the setting for that one?
timrowledge
Mon Dec 18, 2017 5:52 am
Not quite: disable vnc in the preferences so that it is not coupled to the ‘real’ screen. Then use ‘vncserver ‘ to make a virtual screen. You can specify the resolution of that screen with (IIRC) -randr 1280x1024 (for example). There are about forty-gazillion options to read about in the RealVNC documentation. Some of them even seem to do something useful!
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Khatharr
Mon Dec 18, 2017 6:07 pm
Okay, I had to monkey with it for a while, but I got it working. It looks like it uses 5900 for the bundled server, but when you start it from the CLI it shows something like "192.168.1.99:1", where the appended 1 is the "display number". It turns out the port to connect to is 5900 + that number, which would be neat if it were written down somewhere. Oh well.
Thank you for your help, you two. :D
mattmiller
Mon Dec 18, 2017 6:52 pm
Coming to this one late but I run all my Pi headless using standard VNC server and the only thing I change is
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=1900
framebuffer_height=1024
in /boot/config.txt
nothing else needed at all
knute
Tue Dec 19, 2017 4:27 pm
# overscan.
in /boot/config.txt
+1
Roken
Wed Jan 03, 2018 8:28 pm
OK, driving me nuts. I've tried editing /boot/config.txt and for me, it still gives me a 720x480.
I've tried setting via raspi-config - with the same result. (raspi-config on the tiny display does confirm 1920x1080 (which is what I want).
So how do I get a 1920x1080 via vnc?
Sorry to hijack, but it's the same problem. May not be a problem at the end of the month, since I'm considering buying a dedicated screen and one of those dinky little keyboards, but for now....
Edit: For info, the client is Archlinux using realvnc-vnc-viewer
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
beta-tester
Wed Jan 03, 2018 9:34 pm
can you try this in config.txt:
hdmi_force_hotplug=1
hdmi_force_mode=1
hdmi_drive=2
hdmi_group=1
hdmi_mode=16
this should force to use [email protected] even no monitor is plugged,
https://www.raspberrypi.org/documentati ... t/video.md
on my RPi it has direct effect to vnc resolution to force it also to use 1920x1080.
{ I only give negative feedback }
RPi B (rev1, 256MB), B (rev2, 512MB), B+, 2B, 3B, 3B+, ZeroW, 4B (4GB), ...
Roken
Wed Jan 03, 2018 9:56 pm
Nope. Just the same:
$ xrandr
Screen 0: minimum 320 x 200, current 720 x 480, maximum 2048 x 2048
HDMI-1 disconnected primary (normal left inverted right x axis y axis)
Composite-1 unknown connection 720x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   720x480       62.69*
DSI-1 disconnected (normal left inverted right x axis y axis)
EDIT: I tried replacing openbox with xfce (much more my comfort zone) in the hope that I could use the display settings, but nothing available there, either.
Roken
Wed Jan 03, 2018 10:02 pm
Probably going to leave it until weekend to keep trying. Gotta go to my parents tomorrow (already missed festivities and dad's birthday with them) and I still have work to think about :(
mattmiller
Wed Jan 03, 2018 11:01 pm
paste contents of your config.txt
Better still - stick this in it instead
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
framebuffer_width=1280
framebuffer_height=720
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
All I've done is alter framebuffer sizes
(I don't have a monitor capable of the sizes you want but the above settings should give you 1280x720
If they do - change them to what you want and reboot to see if it works
Roken
Thu Jan 04, 2018 10:20 pm
OK, you got me there, not so much with what you have, as with what you don't.
I already had the framebuffer set, and so time to try commenting out where you had commented and I didn't. None made a difference. However, I have an entry that you don't:
dtoverlay=vc4-kms-v3d
This was enabled. Commenting out and rebooting got me full resolution on vnc.
Thank you :)
Daegara
Wed Jan 31, 2018 2:03 am
Roken wrote: OK, you got me there, not so much with what you have, as with what you don't.
Thank you :)
Just stumbled upon this issue too - Can confirm commenting out this line works.
(The line relates to device tree item of the *experimental* Open GL display driver; disabling or commenting out that line provides the desired virtual server behaviour rather than you being limited to 720x480 which it locks to when enabled.
syscorp
Sun Apr 15, 2018 11:09 pm
yes!!! thanks so much! it works...
have full resolution working again with no HDMI connected.
crowmagnumb
Sun May 06, 2018 2:31 am
This was solved for me by uncommenting out the framebuffer_width and framebuffer_height properties and rebooting.
# overscan.
amitray
Sat Oct 27, 2018 5:53 pm
I too faced the same issue and disabling dtoverlay=vc4-kms-v3d in config.txt file solved it. Many many thanks for that.
Srandista
Thu Dec 13, 2018 7:51 pm
I had the same problem with headless Pi and RealVNC. Thanks to this topic, I was able to fix it. Just one advice, you don't have to completely disable OpenGL driver, if you don't want to. You can set dtoverlay=vc4-fkms-v3d, which is experimental GL driver with so called Fake KMS. With this setting, Pi will start with set resolution from config.txt and functional GL driver, even with headless configuration,.
mandaltechtv
Mon Dec 24, 2018 8:49 pm
Worked for me!
Suggest
sudo vi /boot/config.txt
as this file needs root permission to edit
# overscan.
in /boot/config.txt
jimjtron
Tue Jan 29, 2019 9:41 am
Gidday. Just wanted to confirm and thank Beta_tester for the code he submitted which worked on my RPi 3.
I was using Teamviewer Server and knowing that it was based upon VNC I thought I would try the code suggested and it worked.
hdmi_force_mode=1 THIS ONE I COULDN'T FIND AND DIDN'T USE.
hdmi_drive=2
hdmi_group=1
hdmi_mode=16
It had cost me lots of hours searching internet and stuffing around with a DVI monitor switching back and forth between Macosx & the Pi.
Can confirm #hdmi_safe=1 did NOT help and hdmi_force_hotplug=1 by itself did NOT cure the problem.
Thanks once again.
JimJtron
OMR
Tue Jul 16, 2019 9:49 pm
This is still true for the Pi 4, just comment out the line in the [pi4] section:
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
Ram.Sh
Fri Aug 23, 2019 8:12 am
[pi4]
max_framebuffers=2
THANKS!!!
Chupo_cro
Sun Nov 24, 2019 9:14 am
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
So what is the display's size when the monitor isn't connected and from where those numbers arrive? Are they hardcoded? In other words, where are the default framebuffer_width and framebuffer_height parameters set in case there isn't a monitor and framebuffer_width and framebuffer_height are not configured in /boot/config.txt?
Chupo_cro
Return to “Raspbian”
