aegir
Raspbian cannot be downloaded [solved]
Sat Dec 16, 2017 11:14 am
Repository seems to have a trouble or the file is corrupted. Downloading 2017-11-29-raspbian-stretch.zip hangs at byte 871375784. Here is wget output (in french, sorry) :
2017-12-16 12:05:01 (0,00 B/s) — Erreur de lecture à l'octet 871375784/1764972666 (Connexion ré-initialisée par le correspondant). Nouvel essai.
--2017-12-16 12:05:11--  (essai : 17)  http://director.downloads.raspberrypi.org/raspbian/images/raspbian-2017-12-01/2017-11-29-raspbian-stretch.zip
Connexion à director.downloads.raspberrypi.org (director.downloads.raspberrypi.org)|93.93.130.214|:80… connecté.
requête HTTP transmise, en attente de la réponse… 206 Partial Content
Taille : 1764972666 (1,6G), 893596882 (852M) restant [application/zip]
Enregistre : «director.downloads.raspberrypi.org/raspbian/images/raspbian-2017-12-01/2017-11-29-raspbian-stretch.zip»
director.downloads.raspberrypi.org/raspbian/images/raspbian-2017-12  49%[++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++        ] 831,01M  --.-KB/s    in 0s
2017-12-16 12:05:12 (0,00 B/s) — Erreur de lecture à l'octet 871375784/1764972666 (Connexion ré-initialisée par le correspondant). Nouvel essai.
Re: Raspbian cannot be downloaded
Sat Dec 16, 2017 5:22 pm
Have you tried wget -c http://director.downloads.raspberrypi.org/raspbian/images/raspbian-2017-12-01/2017-11-29-raspbian-stretch.zip
[or wget --continue ...url here ...]? That should attempt to restart (continue) a broken download.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
aegir
Sat Dec 16, 2017 6:30 pm
Yes I tried, but it always failed for the byte #871375784
Finally I've downloaded it with bittorrent, but it seems that the http file has/had a problem.
pbpersson
Sun Dec 17, 2017 12:58 am
I have tried downloading this two ways and extracting it two ways. The SHA256 key that is displayed (1fc5a29c33b0fa31a98c2aee188a257cafa037aea61115b8d2191214be77765a) does not match what is shown on the website. When I use Win32 disk imager it says "Verification failed at sector: 8192"
This is very disappointing as I had set aside time today to try the Raspbian Stretch image. :cry: :cry: :cry:
klricks
Sun Dec 17, 2017 4:33 am
The SHA256 must be applied to the raw compressed .zip file... NOT to the unzipped .img file.
Try the recommended Etcher software instead of Win32diskimager. Etcher It is easier to use and automatically unzips the image as it goes.
If you still have problems then verify that your SD card is not broken or not a fake. Google for SD fake checker software.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
HawaiianPi
Sun Dec 17, 2017 11:17 am
That is the correct sha256 for the extracted image. The published one is for the .zip download. Since your sha256 checks out, the verification error must be a problem with writing the card.
Bad card (is it a Kingston by any chance)?
Bad card reader?
Bad .zip extraction (how did you extract the file)?
Hard to say for sure...
Try another SD card and/or card reader if you have them.
Try the Etcher software and let Etcher do the extraction and writing (don't extract the image file, let Etcher write the .zip download file).
https://etcher.io/
pbpersson
Sat Dec 23, 2017 7:29 pm
I used Etcher and it took a couple of tries but I was able to get this to work.
Thank you! :D
Phil
Return to “Raspbian”
Who is online
Users browsing this forum: HOD, LTolledo and 19 guests
