Page 2 of 4
Re: [HowTo!] Smooth youtube 1080p in Chromium
Posted: Tue Jun 19, 2018 8:56 pm
by fjleon
today i am not getting crashes, but the videos pause without an ability to unpause them within a few minutes. this is so inconsistent for me.
of course i would like to figure out why i cannot turn on the kms driver without crashing chromium. maybe i will retry raspbian over the weekend from scratch again
Posted: Mon Jul 02, 2018 7:57 pm
by jms301
Hi fjleon,
Did you solve your problem of intermittent video freeze?
I'm seeing the same problem on a 3B+ playing local H.264 videos
I haven't attempted applying all the modifications in this thread yet so I'll give that a go tomorrow.
Posted: Mon Jul 02, 2018 9:26 pm
by fjleon
i reformatted yesterday and put raspbian back in. ran the script on this thread twice (because it has some bug and the chromium modifications don't get inserted in the file somehow). also i put 192 MB to the graphics card in the config file.
after doing that i am getting decent results in the smores website. no crashes so far and only a couple of video pauses. However i also tried youtube just for testing and it can't handle 1080p full screen, it skips around 80% of the frames.
note that i didn't try to use one of the experimental opengl drivers and chrome://gpu shows very little accelerated processes.
note that i also didn't run apt-get upgrade so chromium is still at version 62 and getting lots of warnings about flash being too old.
Posted: Tue Jul 03, 2018 7:58 am
by ztealmax
Hmm i think this is verry weird as it works great for me, i wonder what makes your setup not work as it should,
i could upload an .img for you to try out if you want.
Posted: Tue Jul 03, 2018 2:45 pm
by fjleon
i don't really care about 1080p but i appreciate the offer. what i am curious to see is a screenshot of your chrome://gpu and maybe your whole config.txt and what chromium version are you using.
Posted: Fri Jul 20, 2018 5:30 pm
by ztealmax
Sorry havent been on much, will post it later today :)
Posted: Fri Jul 27, 2018 9:18 am
by ztealmax
Sorry have been working to much, ill fix it this weekend and put up an downloadable image so you can test it with out doing mods to your own.
//Martin
Posted: Thu Aug 02, 2018 9:19 am
by sgehdn
this HowTo works great, thanks!
One question: I was wondering if this could also work for the videos at www.be-at.tv somehow?
If I star tplaying the videos there, they are still laggy.
Any help is highly appreciated =)
Regards
Posted: Thu Aug 02, 2018 3:06 pm
by fjleon
i really don't have the lag problem. the problem is that chrome leaks memory and it will crash with the "aw snap" message. It can be after 5 minutes, it can be after 4 hours, but it WILL crash.
also, there is no combination i have been able to find that lets me enable hardware acceleration without chromium instantly crashing when a video plays. so i have to use the default GL driver and i can't enable the option in chromium that says something like "ignore blacklist of devices", which is the one that will enable hardware acceleration (chrome:gpu shows all green after doing this)
Posted: Thu Aug 02, 2018 4:43 pm
by ztealmax
This is my config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=82
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# I have disabled audio in this config *Using small usb audiocard with mic and headphones Config works with build in audiocard also
dtparam=audio=off
# Disabled builtin Bluetooth as im not using it.
dtoverlay=pi3-disable-bt
# Changed Color depth to 32bit
framebuffer_depth=32
framebuffer_ignore_alpha=1
# My memory for GPU is set to 192Mb
gpu_mem=192
This is my chromium customization:
CHROMIUM_FLAGS="--disable-quic --enable-fast-unload --enable-tcp-fast-open --disable-gpu-compositing --enable-native-gpu-memory-buffers --enable-gpu-rasterization --enable-zero-copy"
With this config it works great for me, im not using KMS driver but rather OpenglES thats allready activated at install, but have had it run with KMS and that also works.
Regarding www.be-at.tv think it forces player in shockwave flash and im not using flash in my settup im affraid, but can try and install and try it out during weekend.
Posted: Thu Aug 02, 2018 4:51 pm
by fjleon
you have some changes to the config.txt worth checking. i will try them later tonight.
your chromium flags won't really do anything if you are not enabling the option to ignore the blacklist provider setting. your chrome://gpu should show that hardware acceleration is disabled and that's why using the opengl driver doesn't produce an instant crash.
also, it may be just be that you are using this for a few minutes a day and don't experience crashes. remember i am trying to actually use it 8-16 hours a day straight to earn money from watching ads.
Posted: Thu Aug 02, 2018 4:55 pm
by ztealmax
You probebly are correct been changing and testing my settings so much so it might be that.
Graphics Feature Status
Canvas: Software only, hardware acceleration unavailable
CheckerImaging: Disabled
Flash: Unavailable
Flash Stage3D: Unavailable
Flash Stage3D Baseline profile: Unavailable
Compositing: Software only. Hardware acceleration disabled
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Hardware accelerated
Rasterization: Hardware accelerated
Video Decode: Unavailable
WebGL: Hardware accelerated but at reduced performance
WebGL2: Unavailable
Driver Bug Workarounds
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
decode_encode_srgb_for_generatemipmap
disable_framebuffer_cmaa
disable_post_sub_buffers_for_onscreen_surfaces
scalarize_vec_and_mat_constructor_args
Problems Detected
Accelerated video decode is unavailable on Linux: 137247
Disabled Features: accelerated_video_decode
Only enable WebGL for the Mesa Gallium llvmpipe driver: 571899
Disabled Features: flash_stage3d, gpu_compositing, gpu_rasterization, flash3d, accelerated_webgl2, accelerated_2d_canvas, accelerated_video_decode, flash_stage3d_baseline
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Mesa drivers in Linux handle varyings without static use incorrectly: 333885
Applied Workarounds: count_all_in_varyings_packing
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
Use GL_INTEL_framebuffer_CMAA on ChromeOS: 535198
Applied Workarounds: disable_framebuffer_cmaa
Disable partial swaps on Mesa drivers (detected with GL_VERSION): 339493
Applied Workarounds: disable_post_sub_buffers_for_onscreen_surfaces
Decode and encode before generateMipmap for srgb format textures on os except macosx: 634519
Applied Workarounds: decode_encode_srgb_for_generatemipmap
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Don't expose disjoint_timer_query extensions to WebGL: 808744
Gpu compositing has been disabled, either via blacklist, about:flags or the command line. The browser will fall back to software compositing and hardware acceleration will be unavailable.
Disabled Features: gpu_compositing
Checker-imaging has been disabled via finch trial or the command line.
Disabled Features: checker_imaging
Version Information
Data exported	2018-08-02T16:53:04.995Z
Chrome version	Chrome/65.0.3325.181
Operating system	Linux 4.14.52-v7+
Software rendering list URL	https://chromium.googlesource.com/chromium/src/+/abb5172872b726072a64dfabaf45894c6ecf7369/gpu/config/software_rendering_list.json
Driver bug list URL	https://chromium.googlesource.com/chromium/src/+/abb5172872b726072a64dfabaf45894c6ecf7369/gpu/config/gpu_driver_bug_list.json
ANGLE commit id	unknown hash
2D graphics backend	Skia/65 8a3e0b31927ae78bc3e9c342b1290a6a64233674-
Command Line	/usr/lib/chromium-browser/chromium-browser --disable-quic --enable-fast-unload --enable-tcp-fast-open --disable-gpu-compositing --enable-native-gpu-memory-buffers --enable-gpu-rasterization --enable-zero-copy --enable-pinch --flag-switches-begin --flag-switches-end
Driver Information
Initialization time	893
In-process GPU	false
Passthrough Command Decoder	false
Direct Composition	false
Supports overlays	false
Sandboxed	false
GPU0	VENDOR = 0x0000, DEVICE= 0x0000 *ACTIVE*
Optimus	false
Optimus	false
AMD switchable	false
Driver vendor	Mesa
Driver version	13.0.6
Driver date
Pixel shader version	1.30
Vertex shader version	1.30
Max. MSAA samples	0
Machine model name
Machine model version
GL_VENDOR	VMware, Inc.
GL_RENDERER	Gallium 0.4 on llvmpipe (LLVM 3.9, 128 bits)
GL_VERSION	3.0 Mesa 13.0.6
GL_EXTENSIONS	GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_KHR_context_flush_control GL_KHR_debug GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_MESA_ycbcr_texture GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
Disabled Extensions	GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
Disabled WebGL Extensions	EXT_disjoint_timer_query EXT_disjoint_timer_query_webgl2
Window system binding vendor	SGI
Window system binding version	1.4
Window system binding extensions	GLX_ARB_create_context GLX_ARB_create_context_profile GLX_ARB_fbconfig_float GLX_ARB_framebuffer_sRGB GLX_ARB_multisample GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_EXT_fbconfig_packed_float GLX_EXT_framebuffer_sRGB GLX_EXT_import_context GLX_EXT_libglvnd GLX_EXT_texture_from_pixmap GLX_EXT_visual_info GLX_EXT_visual_rating GLX_MESA_copy_sub_buffer GLX_OML_swap_method GLX_SGI_make_current_read GLX_SGIS_multisample GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGIX_visual_select_group
Window manager	Xfwm4
XDG_CURRENT_DESKTOP	XFCE
Compositing manager	No
Direct rendering	Yes
Reset notification strategy	0x8261
GPU process crash count	0
System visual ID	33
RGBA visual ID	65
Compositor Information
Tile Update Mode	Zero-copy
Partial Raster	Enabled
GpuMemoryBuffers Status
ATC	Software only
ATCIA	Software only
DXT1	Software only
DXT5	Software only
ETC1	Software only
R_8	Software only
R_16	Software only
RG_88	Software only
BGR_565	Software only
RGBA_4444	Software only
RGBX_8888	Software only
RGBA_8888	Software only
BGRX_8888	Software only
BGRX_1010102	Software only
BGRA_8888	Software only
RGBA_F16	Software only
YVU_420	Software only
YUV_420_BIPLANAR	Software only
UYVY_422	Software only
Display(s) Information
Info	Display[0] bounds=0,0 1920x1080, workarea=0,0 1920x1080, scale=1, external
Color space information	{primaries:INVALID, transfer:INVALID, matrix:INVALID, range:INVALID}
Bits per color component	8
Bits per pixel	24
Video Acceleration Information
Log Messages
[963:963:0802/164139.717632:ERROR:sandbox_linux.cc(375)] : InitializeSandbox() called with multiple threads in process gpu-process.
testing to add --ignore-gpu-blacklist again to see effect
Yea looked better in chrome://gpu "again" :)
However i never had that problem you had i used to have --ignore-gpu-blacklist just forgot to add it since i changed lots of things
anyway i will try and run a bunch of videos from youtube in 1080p repetetly until tomorow "autoplay
Ill get back to you
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Video Decode: Hardware accelerated
WebGL2: Hardware accelerated
Problems Detected
Version Information
Data exported	2018-08-02T16:58:36.364Z
Command Line	/usr/lib/chromium-browser/chromium-browser --ignore-gpu-blacklist --disable-quic --enable-fast-unload --enable-tcp-fast-open --disable-gpu-compositing --enable-native-gpu-memory-buffers --enable-gpu-rasterization --enable-zero-copy --enable-pinch --flag-switches-begin --flag-switches-end
Driver Information
Initialization time	778
Sandboxed	false
Optimus	false
Optimus	false
Driver vendor	Mesa
Driver date
Max. MSAA samples	0
Machine model name
System visual ID	33
RGBA visual ID	65
ATC	Software only
ATCIA	Software only
DXT1	Software only
DXT5	Software only
ETC1	Software only
R_8	Software only
R_16	Software only
RG_88	Software only
Bits per pixel	24
Log Messages
[872:872:0802/165812.209354:ERROR:sandbox_linux.cc(375)] : InitializeSandbox() called with multiple threads in process gpu-process.
Final chromium customization:
CHROMIUM_FLAGS="--ignore-gpu-blacklist --disable-gpu-compositing --disable-quic --enable-fast-unload --enable-tcp-fast-open --enable-checker-imaging --enable-native-gpu-memory-buffers --use-gl=egl --gles --enable-gpu-rasterization --enable-zero-copy"
Posted: Thu Aug 02, 2018 6:24 pm
by sgehdn
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
hdmi_group=2
hdmi_mode=82
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=off
gpu_mem=192
This would be great, thanks :)
Posted: Thu Aug 02, 2018 10:43 pm
by fjleon
ok i just found out that chromium is not using the 00-piws file. so basically it's using whatever it wants to use and you can change it by yourself using chrome://flags.
so it seems like the script posted won't really do anything because chromium will just ignore it.
it's more confusing since /etc/alternatives/x-www-browser mentions that you should place the flags over the customizations folder as you did.
Posted: Fri Aug 03, 2018 6:01 am
by ztealmax
Ok that's extremely weird post your chomium 00-piws configuration please so I can see what's wrong
It might be a typo in my script.
It does work for me hmm
Ive been running my raspberry pi youtube in chromium at 1080p fullscreen and autoplay videos without any problems since last evening, no errors no hickups.
You guys want me to upload my installation as an .img its raspbian-lite with pure lxde desktop?
Posted: Tue Aug 14, 2018 4:36 pm
by sgehdn
Hi, are there any news about be-at.tv? :D
Regards
Posted: Mon Aug 20, 2018 6:12 pm
by Pavel G
Hello. I have tried all steps from the top message. Tried to update flags according message in the deep of thread too.
But stil it's not solve the issue with non smoth youtobe playback on fullscreen.
Raspberry Pi 3B, with latest raspbian.
The second issue is when I use --disable-gpu-compositing than my browser begin laging, and can be hanged.
So I enabled gpu compositing, it's solve laging during scrolling, but you tube videos working incredibly slow even in the window mod if I turn turned of h264ify. In case if h264ify is working youtube do not start playback and page is crashing.
I'm using GLES for now, and upscale GPU mamory to 256 (192 the same behavior).
Current script what I'm using
# * Project: 00-piws-vars                                          *
# * Created: 05/06/2018 22:27                                          *
# * Author: Martin Svensson aka ztealmax - pi-workbench.org            *
# * Info: create in /etc/chromium-browser/customizations/              *
# * Note: replaces rpi-chromium-mods                                   *
PICHROMIUMMODS="/etc/chromium-browser/customizations/00-rpi-vars"
if [ -f "$PICHROMIUMMODS" ];
then
   echo "$PICHROMIUMMODS purge rpi-chromium-mods..."
      sudo apt-get remove --purge --autoremove -y rpi-chromium-mods
else
   echo "rpi-chromium mods not present all is good..." >&2
# -[10]-chromium-customizations.sh--------------------------------------
sudo -- sh -c "echo 'CHROMIUM_FLAGS=' >> /etc/chromium-browser/customizations/00-piws-vars"
sudo sed -i 's/'CHROMIUM_FLAGS='/''CHROMIUM_FLAGS="--ignore-gpu-blacklist --enable-gpu-compositing --disable-quic --enable-fast-unload --enable-tcp-fast-open --enable-checker-imaging --enable-native-gpu-memory-buffers --use-gl=egl --gles$
# -------------------------------------------------------------[10]-END-
echo "piws-chromium modifications is now installed..."
fi
Config.txt
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
gpu_mem=256
dtoverlay=vc4-fkms-v3d
#dtoverlay=vc4-kms-v3d
All rows there chrome://gpu/ is green
Please help, what I'm doing wrong?
Posted: Mon Aug 20, 2018 11:44 pm
by fjleon
try using the default GL driver and deleting --ignore-gpu-blacklis from your script, for me it causes an instant crash anyway.
Posted: Tue Aug 21, 2018 12:37 am
by cjan
try --disable-gpu-driver-bug-workarounds
Posted: Tue Aug 21, 2018 6:57 pm
by Pavel G
I've tried all variants with fake and full GL driver. Tried diferent combination of flags including --disable-gpu-driver-bug-workarounds
So, the main idea still the same:
1) If we are disable gpu composition - than we have lags on scrolling and very very slowy youtube playback
2) if we remove flag regarding gpu composition, lags on scroll are disapeared, but youtube playback crashing on start
Above statement actual if h264ify is turned on.
So, for now I have returned to standart config with no GL driver, but some flags still turned on, but I think it's not impact perfomance, works like standart config. On 720p fullscreen it laging if scroll bar on you tube is visible, but when it hiden it work not bad, not idealy, but not bad.
If somebody solve issue with GL drivers and h264ify, please share full config and your flags, thanks.
Posted: Tue Aug 21, 2018 9:42 pm
by ztealmax
i have it working 100% please let me check tomorow and reupload my latest script
and a copy of my raspbian.img
Sincerlly
Martin
Posted: Tue Sep 18, 2018 2:18 pm
by mattiasottosson
Sincerlly
Martin
I got pretty managed to get pretty smooth playback on Youtube, but all other mp4s are now unfortunately crashing the tab it's running in.
Would be super sweet if you could share your config Martin.
Posted: Tue Sep 18, 2018 3:34 pm
by ztealmax
Ofc m8 i will upload it when i get home, on mobile atm / Martin
Posted: Wed Sep 19, 2018 2:50 pm
by ztealmax
Ill fix it later today ive been away :)
Posted: Mon Oct 01, 2018 7:42 am
by mattiasottosson
:cry:
