McLion
VLC version on Repository
Fri Dec 08, 2017 9:15 am
Hi
Why does the version that can be easily installed from the repository not include the OMX-IL GPU acceleration?
Everyone has to compile it by themselves - I have 2.2.8 with acceleration running perfectly on Jessie so far.
How do we get the compiled version up to the repository, including the acceleration?
Franz
ghans
Re: VLC version on Repository
Fri Dec 08, 2017 9:30 am
Ask forum moderators plugwash or ShiftPlusOne if they can put it in the "rpi" section ??
ksharindam
Fri Dec 08, 2017 10:24 am
They will never include OMX IL output supported version in the repo. Because omxil output does not work when gl driver is enabled.
They will not incllude any app in the repo that does not work properly when gl driver is enabled.
even they haved removed penguinspuzzle from the repo.
ShiftPlusOne
Fri Dec 08, 2017 12:11 pm
We're not quite that hardline about it.
Openmax should be usable regardless of which driver is used (see omxplayer). Also, I believe VLC just adds the option of using omxil, rather than requiring. Send me a patch to the VLC package that makes it work in both scenarios, and I'll gladly add it.
Penguinspuzzle was taken out because it didn't work under stretch. IIRC, it ignores keyboard inputs and we don't have the source code to update it.
ksharindam
Fri Dec 08, 2017 1:12 pm
Glad to hear it . I will try to make a patch.
And one more question, if I send you a patch of ffmpeg with hwaccl support will you include the patch?
ShiftPlusOne
Fri Dec 08, 2017 1:15 pm
ksharindam wrote:Glad to hear it . I will try to make a patch.
That would be much appreciated. It needs to apply on top of the current stretch version.
ksharindam wrote: And one more question, if I send you a patch of ffmpeg with hwaccl support will you include the patch?
If I don't find anything wrong with it, absolutely.
ksharindam
Fri Dec 08, 2017 1:16 pm
Thanks.
Return to “Raspbian”
