candreshidalgo
run code in crontab between hours does not work
Mon Nov 27, 2017 1:29 pm
hello.
I want to run code in crontab between hours every 1 minute but it doesn't work. in reality the code
starts the job at the indicated time (10:00) but it doesn't finish its execution at the indicated time (19:00).
the last line in the crontab is :
* 10-19 * * * /usr/bin/python /home/pi/Desktop/detector.py
if anyone has any idea or solution, please reply
thanks
scotty101
Re: run code in crontab between hours does not work
Mon Nov 27, 2017 2:06 pm
Are you sure that your crontab expressions will do what you want it to?
* 10-19 * * * means “At every minute past every hour from 10 through 19.”
So the task will be run for the first time each day at 10:00 and run until the program stops, it will then try to run again at 10:01, 10:02, 10:03 etc until 18:59.
If your python script never ends (i.e. infinite loop), it won't be stopped by cron. Cron only starts tasks running.
knute
Mon Nov 27, 2017 9:40 pm
hello.
thanks
I'm not a cron expert but I think 10-19 is 10 through 19 inclusive. Meaning 10:00 through 19:59.
candreshidalgo
Sat Dec 02, 2017 12:23 am
yes my python script never ends (i.e. infinite loop),.
Is there a solution to this case?. Does anyone have a suggestion?.
thanks
RonR
Sat Dec 02, 2017 3:11 am
Do your own time checks/timing in your python script, sleeping during inactive periods to give up the cpu. Launch your script from /etc/rc.local with a trailing '&' to have it detach and run separately.
scotty101
Mon Dec 04, 2017 11:10 am
thanks
Schedule a second crontab task to occur at the end of the scheduled time.
This task should run a command to kill the existing application.
Have a read online for ways to kill running applications.
Here is one example https://stackoverflow.com/questions/406 ... ash-script
Return to “Raspbian”
